How to scale Romany Charm set?…
Daz 3D Forums > General > The Commons>How to scale Romany Charm set?…
How to scale Romany Charm set? {solved}
The setting is too big compared to v4/m4, and I can't simply rescale v4/m4 to fit beacuse then the dynamic clothing won't fit. Problem, though, I don't see how to scale it.
Help?
Post edited by WillowRaven on
Should just be a simple scale setting. If the set has separate props for the interior, parent them to the main section before scaling and all 'child' entities will scale down accordingly. If the scale option is missing then ensure sure you make hidden controls visible in the options.
That made the dial appear, but even though parented, nothing re-scales at the same rate.
Try adding the item to a null and then scaling the null. I find this works wonders in situations like that.
So how do I do that?
Create -> New Null
Parent the item to the null and then rescale the null. Sometimes you find that it's not the scaling which is the issue, but the positions not changing so that they scale in place. This means that when the object shrinks or expands, items essentially seem to move from their original spots.
That did the trick, thanks :D
Glad to be of help. If you edit your original post you can put a [solved] tag on the end to indicate that all is well :)
Done :D Thanks, again :D
The Solved was Noted and very much appreciated my this Mod. TY for being so kind as to do that. TY also HOF for the suggestion.
