black / white renders daz 4.7
Hi, i have small problem
i bought a new pc, install everything like in old one, render settings, libary files etc... and...my renders dont look the same like in old pc
1. File created on old pc - rendered on new pc - file 01
2. File created on new pc - rendered on new pc - file 02
3. File created on old pc - rendered on old pc - file 03
any ideas what's wrong?
regards
Y.Y
1000 x 667 - 261K
1032 x 882 - 276K
1032 x 882 - 290K
  • Richard HaseltineRichard Haseltine Posts: 104,085
    1) looks as if a needed shader hasn't been installed
    2) looks as if a Shader Mixer shader has been miscompiled - go to the DS temp folder (location in Edit>Preferences), then in that to Shaders\Brickyard and delete the contents of the folder. Then try rendering again.
    3) not sure - is there anything at the end pf the log file? Do you get a crash report?
  • edited December 1969
    1) hmmm..but shader is installed, applayed. on old pc it works on new..no
    2) i dont have Brickyard folder in Shaders
    3) that render is ok - on old pc, after open that scene on new pc i have "01"problem
    - yes - i have somelike that in daz render callculate window:
    verity 2): dspy_dsm: cannot open output file 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d166_Ambient-04.shd' (system error: Invalid argument)
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d89_B_EOSLong.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_LongHair_2035_7e4')
    3Delight message #3 (Severity 2): T2373: cannot read 3D texture file 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d88_T_EOSLong.tdl' (Invalid argument) (in shader 'dzdefaultshadow' on object 'shapematerial_LongHair_2035_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d80_B_EOSTop.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_TopHair_2031_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d86_B_EOSALL.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_Over_2034_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d83_B_EOSBkFt.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_FrontHair_2038_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d81_03_EOSBkFt.tdl' not found (in shader 'dzdefaultshadow' on object 'shapematerial_FrontHair_2038_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d126_B_EOSScalp.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_Scalp_2039_7e4')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d67_Amber_faceB.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object 'shapematerial_Face_2213_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d75_Amber_bodyB.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object 'shapematerial_Head_2217_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d65_Amber_limbsB.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object 'shapematerial_Shoulders_2219_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d137_WWTopsBp1.tdl' not found (in shader 'dzdisplace' on object 'shapematerial_Tank_2133_84e')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d77_Amber_lashes1.tdl' not found (in shader 'dzdefaultshadow' on object 'shapematerial_Eyelashes_2013_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d73_Amber_cornea.tdl' not found (in shader 'omnifreaker/surface/omShadowSurface' on object 'shapematerial_Cornea_2212_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d72_Amber_iris4.tdl' not found (in shader 'omnifreaker/surface/omShadowSurface' on object 'shapematerial_Irises_2210_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d70_Amber_tear.tdl' not found (in shader 'dzdefaultshadow' on object 'shapematerial_Tear_1995_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d68_Amber_eyes.tdl' not found (in shader 'omnifreaker/displacement/omDispStandard' on object 'shapematerial_Sclera_2215_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d135_WWPantsDis1.tdl' not found (in shader 'DAZ/Uber/displacement/omDispStandard' on object 'shapematerial_Pants_2230_837')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d69_Amber_lips5.tdl' not found (in shader 'dzdefaultshadow' on object 'shapematerial_Lips_1994_7b2')
    3Delight message #3 (Severity 2): T2040: 'C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d76_Amber_body - Kopia.tdl' not found (in shader 'omnifreaker/surface/omShadowSurface' on object 'shapematerial_Hips_2221_7b2')
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Pants_2230_837' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omShadowSurface') used only 0% of its displacement bound
    but on old PC i have the same words;) and it works perfect...
    1) did you install, or did you copy the content folders across from the old machine?
    2) on your machine it will be C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/Shaders/Brickyard
    problem is the same after copy/paste all "daz 3d" folder from roaming old mashine to new pc
    new scene + new pc = render white
    old pc scene + new pc = render black
    and it shows the same log in render windown
    daz 4.6 the same, daz 4.5 the same...
    all drivers are uptaded
    win 7 64bit, 16gb ram, i7-3770, geforce gtx 680
    Instead of copying the content folders try installing the default lights and shaders fresh on the new PC - with plugins and shaders (and some scripts) there are files that need to go in the application folder, as well as the files for the content directories.
  • yxk03yxk03 Posts: 19
    Hi, it sounds like maybe programs aren't able to write to the directory C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp, for some reason, and the reason for the "not found" errors is that tdlmake, which was supposed to generate those files earlier, wasn't able to write to the directory either. Are you able to navigate to that directory with Windows Explorer and paste a file? (When you get to C:/Users/U?ytkownik you'll probably have to click in the top bar and add "/AppData" to the end of the name by hand.)
    Actually
    "cannot open output file ‘C:/Users/U?ytkownik/AppData/Roaming/DAZ 3D/Studio4/temp/d166_Ambient-04.shd’ (system error: Invalid argument)"
    is what you'd get if something failed to understand whatever the second character in U?ytkownik is, I assume it's not really a question mark. If nothing else works and you're obsessed enough with getting the problem solved, you could try making yourself an account with only unaccented latin characters in the name and see what happens if you render from there.
    Actually
    That would be my guess, too.
    The non-Latin character. Studio can be picky about things like that.
    ok, thx it works:):):)
    after reinstal system - change user name for one without special symbols ;)
    thx once again :)
    best regards
    Y.Y
