Pivot point in Poser
BurpeeBurpee Posts: 152
edited December 1969 in Poser Discussion
Is it possible to move your pivot point on a prop in Poser? I made an object in Hexagon but it does not retain the new pivot point that I gave it. The pivot point goes back to the center of mass center.
  • edited December 1969
    Yes, open the Joint Editor (Ctrl+Shift+J) and enter the coordinates of the Center Point.
  • BurpeeBurpee Posts: 152
    Excellent! Thank you.
  • Richard HaseltineRichard Haseltine Posts: 103,095
    For a prop in Poser you just need to edit the x-, y- and z-offset parameters.
    Hi Richard, I the Poser manual I can only find the term 'offset parameters' pertaining to the uv mapping and texture. Is this what you mean or is there another area where I can make these changes?
    edited November 2012
    Located the joint editor through the Window tab and moved the center point that way. Never found the offset parameters that affected the center of mass. Thanks both for the help.
    Post edited by Burpee on
