What is SSS?
Daz 3D Forums > General > New Users>What is SSS?
What is SSS?
I know it stands for Sub Surface Scattering but what is it's function? What is it good for? I'm not looking for a technical definition exactly. Just more of an idea of what it is typically used for, what the benefits or draw backs are. I have some products that offer SSS settings and I was curious if I was missing out on better renders.
Thanks!
In the real world Subsurface Scattering refers to the property of human skin (and certain other materials) to absorb light and literally scatter it about beneath the surface. Since skin is composed of multiple layers of translucent material, some light passes through the outer layers to those beneath where it is eventually reflected and refracted. In 3D use it is an attempt to replicate this effect to produce more realistic skin on the models.
Skin, most plastics, wax, cloth...basically anything that is translucent. Metals and things like glass/crystal don't have it (although some things like opals, do).
In 3D terms, think of it as depth controlled translucency for 'thick' things.
Ahhh!
Does DS support SSS now?
Is the DS version different from the poser version?
DS has supported SSS for a long time now actually it supported it before Poser did.
So if I may ask on the same subject, I see settings for sss on some models of 25%, 50% and 75% - how does one decide on whic to use ? For most 'realistic', is 75% best ?
Thanks
Steve
I thought there was a Poser subsurface shader for which the materials designed for it don't work (or don't work that way) in DS, plus a separate SubSurface shader (like the SubSurface goop shaders, etc.) unrelated to it. Is that incorrect? I'm wondering if I need to go digging in my trash bin for all the SSS settings I deleted thinking they were Poser-only.
