Render Studio Iray problem in DS 4.9.3.166
TaozTaoz Posts: 10,319
edited January 2017 in The Commons
I've noticed a problem with the Render Studio Iray "Infinity Cove" backdrop in DS 4.9.3.166. There used to be a smooth transition between the grey colors, not there are some sharp lines at the bottom. Any idea what is causing this?
600 x 700 - 175K
Post edited by Taoz on
  • TheKDTheKD Posts: 2,711
    edited January 2017
    Yep, I am getting the same thing. Also tried adding smoothing modifier on it, didn't help any. Adding subd made it worse. First one is subd, second one is smoothing.
    900 x 1125 - 524K
    900 x 1125 - 535K
    Post edited by TheKD on
  • TaozTaoz Posts: 10,319
    OK, will file a bug report then...
    Happened to the one I made for myself as well, tho not quite as drastic.
    Laurie
    Hmmmm, maybe the mesh is just too thin. I looked at a bunch of other stuff with smooth curves, and didn't see the same artifact happenning. One thing I found that helps is a little, is turning off thin walled in the surface options.
    900 x 1125 - 587K
