Where can I find the Genesis 3 Female Base texture?
I've looked through all the folders I possible can for it, but I can't seem to find the skin texture. Supposedly it should be under "Users/Public/Documents/My DAZ 3D Library/Runtime/Textures" but it isn't there. There isn't even a Genesis 3 Female folder in there. There's a Genesis 3 Female folder in the People folder with a Materials folder in it, but that's just filled with .duf files and I haven't the faintest idea if one of them has the default skin texture in it and how I would even get it out. All I want to do is change the color of the texture in an image editing program and then put it back into DAZ as an option in case I want to make a character using it.
Another reason I need the texture file anyway is because I plan to use the finished model in other programs such as Blender, but without a texture of any kind all I have is a grey model. Of course, then I'd also need the textures for the eyes and stuff.
The full path will be shown in the pop-up thumbnail if you hover over the micro-thumbnail for a property in the Editor tab of the Surfaces pane. The default Genesis 3 Female textures are in \Runtime\Textures\Raiya\Jeane.
Thank you so much.
With G3 loaded into a scene, select the Surface Selection Tool and have the Surfaces (Color) tab selected on left side of screen (default workspace setup). Click anywhere on the figure and when the information populates in the Surfaces (Color) tab, left click on the skin icon in Base Color. You will get a drop down menu that shows you all the textures loaded. At the top is a 'browse' selection. Clicking that will take you to the folder where the texture is located.
