The shader mixer brick "Light Decay"
edited April 2013 in Daz Studio Discussion
I am trying to tweak the light attenuation and i found the brick "Light Decay" in the shader mixer. Does anyone know how to use it? Where is the output supposed to go?
Jörgen
Post edited by jergenoman_b33d4209f8 on
  • BejaymacBejaymac Posts: 1,906
    It only works with the Gel Light, Point Light & Spot Light root bricks, with one of those three loaded into the work space, you click on the bricks options menu (top right of each brick) and select "show advanced", a new connection called "Decay(1/r^2)" should now be visible on the root brick, that's where you plug in the decay brick.
