RESOLVED: Genesis 8 Basic Male…
Daz 3D Forums > General > Technical Help (nuts n bolts)>RESOLVED: Genesis 8 Basic Male…
RESOLVED: Genesis 8 Basic Male vs Genesis 8 Male Dev Load
Searching has not turned up the magic answer as to what the differences are between these two figures in the Genesis 8 Starter Essentials. Anyone out there able to explain this to me?
Post edited by ArtsyDragon on
The dev load would be used if you're going to create morphs or any type of content development. It deactivates some morphs that would mess up things like teeth if you use the other and forget to turn off those morphs when exporting from DS.
Dev load also doesn't load the eyelashes, which can make all your work worthless if you forget to turn them invisible before exporting.
Thank you for that. Now I get it.
