Breast Manipulation
Daz 3D Forums > General > New Users>Breast Manipulation
Breast Manipulation
Hi all. What product do I need to manipulate the breast to any extent needed to make laying down etc look real? G8F Thanks!
Post edited by OminousAutumn on
This only works on G3: https://www.daz3d.com/i13-squish-soft-body-effect-morphs-for-the-genesis-3-female-s
Seconded! Zev0 makes the best add-ons to control aspects of the models that are left out of the base.
There is also this new dForce product: FG dForce Breast Presets for Genesis 8 Female
https://www.daz3d.com/fg-dforce-breast-presets-for-genesis-8-female
I'm not sure, but dForce could work on other Genesis versions as well.
And also,
i13 SQUISH Soft Body Effect Morphs for the Genesis 3 Female(s)
The dForce product has just a very limited ability, and it only works on G8F.
Laying down... you could also add your own deformer.
Now... this is the interesting part. You may have a thing in the scene that you want your breasts to interact with, but I find it's typically better to make a separate interactive breast moving item.
You typically do not want the actual Floor or Table or whatever to be the thing that interacts with your boobies. (Usually, there's a lot more in close proximity with the floor than the boobies, so this leads to all sorts of unwanted interactions.)
So... what you want to do...
This forces the figure to "smooth" itself out around/over the "Collision Item".
You can move the "Boobies Mover" plane up and down to arrive at the right level of flattening interaction with the boobies in your scene.
