Convert an obj character to a …
Daz 3D Forums > Software > Daz Studio Discussion>Convert an obj character to a …
Convert an obj character to a g8 character
so here I would like to totally convert (texture included) a character (in file obj)
as a character for Genesis 8; would it be possible?
I have been looking for a while but I have not found anything concrete.
I wish it became a character for genesis 8.
Thank you for your answers.
Please don't post images of nude figures.
I'm not sure what you are trying to do - is the character in OBJ format a different mesh with different UVs? If so then not in DS, though it should be possible using the cosntraints (to match the shape) and texture baking tools in many modellers to create a morph for the base resolution Genesis 8 Female and to produce versions of the maps for the Genesis UVs.
In fact I would like to make this character (obj) a character for the genesis 8 female (g8f) with textures and morphs.
I would like to know how to make that possible.
Thank you in advance.
I think the basic techniques I suggested above are discussed in the threads on transferring morphs and maps to Genesis 3 from older geenrations, the fact that you are starting from an OBJ rather than an older figure should not chnage the basic methods (though you won't have a clone shape to start from). Sorry, I don't have links to hand.
Assuming this obj is not made from the Genesis 8 Female mesh and using the Genesis 8 Female UV mapping, then not without a lot of work and knowledge on your part. What is the source of your obj? Is it a character made for an earlier Daz base, such as Victoria 4 or an earlier Genesis model, or is it from elsewhere?
