HDR Iray Skies for scene in th…
Daz 3D Forums > General > Technical Help (nuts n bolts)>HDR Iray Skies for scene in th…
HDR Iray Skies for scene in the ocean, all the HDR Environments that i see have land
Hi, I'm trying to create a marine scene, so I've set out to test HDR backgrounds with Iray to get this effect of blue sky with clouds and lighting.
The main problem I see in all the HDRI Environment Maps is that they always apply a land or mountains between the sky and the model, so I can not create a scene in which my model seems to be in the sea completely because it always has ground below .
Example for this problem
I want create a complete ocean with sky, removing this ground, what could be the best way for that with realistic results?
Examples
Look for agent unawares over at deviant art, he has a number of great quality HDRIs that could work for you.
...an example:
Here are some suggestions from here at the Daz store. I own all of these and have used some of each set. All provide quality results and are just skies without any land.
Dimension Theory's Skies of iRadiance series
High Sky HDRI Bundle for Iray includes the following:
Sedor's Iray Skies
Tks, good to know! Are they .hdr?
Thanks to both of you! I will try this and I will try to create water separately
I hope this thread works for the next one that is in a similar case
Yes. Both vendors provide .hdr files.
Tks
