How to stick out tongue G8F
Daz 3D Forums > General > New Users>How to stick out tongue G8F
in New Users
I've got all kinds of tongue morph tools, but can't figure out the basic step to stick out the character's tongue?
I have a "tongue out" parameter, but opening the mouth I see that the tongues are too short to come out!
I use this free set of tongue poses: https://www.cgbytes.com/store/sku/58309_TonguePlus-For-G8-Couple
To find the tongue morphs, select the G8F figure, then in the Parameters pane, look in Pose Controls and drill down through the levels Head>Mouth>Tongue. The limits for Tongue In-Out are woefully tiny, so click on the little cogwheel on the right of the parameter slider and select Parameter Settings. You can either untick the Use Limits tickbox, or lower the Min limit value to something more sensible like -300% or -400%.
Of course, this leaves the tongue knocking out several teeth, so you'll have to lift it up a bit with a combination of the Tongue Raise-Lower and Tongue Up-Down morphs. If the limits for these aren't enough to do what you want, you can use the same instructions to change their limits.
Thank you both so much! I will try this tonight!!! Very helpful, never would have figured that out with the limits.
Glad to help. Note that it isn't always obvious whether a parameter belongs under Pose Controls or Actor in the Parameters pane. Sometimes a bit of lateral thinking is needed.
