Larger transform gizmos
Daz 3D Forums > Software > Daz Studio Discussion>Larger transform gizmos
I'm not sure if we're allowed to post feature requests in this forum; but, if we are, I have a simple one: I'd like the ability to customize the size of the transform gizmos (specifically, to make them bigger). I find that, on my monitor, they are too small, which not only makes them difficult to click on, but also makes it difficult to make precise adjustments. The ability to increase both the overall size as well as the thickness of the lines would be very useful.
Don't forget that to reach Daz your request needs to go to Technical Support https://www.daz3d.com/help/help-contact-us - it's fien to post to the forusm first, so you can get feedback from other users (including, perhaps, pointing out a way to do what you wantin the current version of DS).
and larger type.
Hopefully some folks in programming are using big monitors.
I upgraded to a 43 inch 4k to make things bigger, particularly the little blue dots when editing mesh/poly in 3d max...
but all the type boxes and gizmos are smaller.
and in both daz and max .. they type sizes are set by the program so they system font settings don't help.
You can increase thickness of the lines of the currently active tool by increasing "Line Width" parameter in Tool Settings tab.
