My Doney is blind!
Leo ChenLeo Chen Posts: 697
edited December 2013 in New Users
http://www.daz3d.com/3d-donkey
Where is my donkey's eyes?
1920 x 812 - 611K
Post edited by Leo Chen on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,949
    that is preview
    do they render?
  • Leo ChenLeo Chen Posts: 697
    that is preview
    do they render?
    Render output.
    are you using the Poser files?
  • JaderailJaderail Posts: 0
    Yes they are, as they load default. Need to apply the DS textures after load.
    I can not find any eye texture file for the DONKEY.
    As shown on the image I attached, there is only one actor file, and the rest are all pose files.
    PS: I used DIM to auto-install the product.
    You do not need the EYE texture only, you need to apply the DS texture to the full figure. For most older content they are only found in the Content Library Tab>My Library>Poser Formats>Pose> and the Item, could Be A MAT folder or other folder, the DS texture is the one with the little scroll on it. I do not have the Donkey so I can not post the exact folder.
  • CyberDogCyberDog Posts: 232
    I just checked and there is no mat pose file. Since the materials are for Poser you need to tweak them in Daz Studio. Someone may have a better idea but what I did was change lighting model for the eyes. select the eyes then go to the surface tab and change the lighting model for the pupil, iris and eye white. They load with the default plastic lighting model. Try changing them to matte. I left the eye transparent as plastic but you can try changing that too. Even with the changes, I don't think the eyes look good enough for a close up.
    Definitely a very old model. No D|S textures; no other textures at all, in fact; no maps for bump or specular; and none of the .rsr thumbnails show in the Content Library tab. This was a very nice model in its day, but it really needs a bit of an overhaul to look good in D|S. As for the eye problem, it's the Poser materials at fault. CyberDog's tip above will at least let you see the textures.
    Thank you all.
    My donkey's eye come back but I just don't know why!
  • Tacos. Lol blew the dust off this ancient model today. Had tha same issue, that was the fix... surfaces > lighting model > matte
