Pregnant Morph for V4...
Alpha ChannelAlpha Channel Posts: 0
...is there one? V3 has one but she's a tad low res for what I need. Basically I've been using V4 as a figure guide for the fashion students at my work place, basically giving them a few basic poses for their fashion poses. One of the students is designing clothing for pregnant women and I thought that lil ol' V4 would have a pregnant morph but I can't seem to see one if she's got it.
If she doesn't anyone one know where I can pick one up?
Thanks
  • Testing6790Testing6790 Posts: 1,091
    I used the one that TheWheelMan linked in a render a few years ago. It's one of the better pregnant morphs out there.
  • Alpha ChannelAlpha Channel Posts: 0
    Thanks for that, I've given them a whirl and they don't do a blessed thing other than twist V4 into knots with no visible sign of a bump. Don't know exactly why though.
  • TheWheelManTheWheelMan Posts: 1,014
    If you Google "Pregnant V4" you'll find a couple of more options, though I don't know why the one above isn't working for you. What program are you using?
    edited January 2014
    Poser 9 (the 3.1 update kills 9 stone dead, refuses to load), Poser 8 and Poser 6. The morphs don't work in any of them while in Poser 8 and 9 the poses themselves give a heady mix of positions that'd give a contortionist trouble or gives the pose but no pregnant body.
    Edit: I'm giving some poses I found on Deviant art a whirl... once I've reset my password :D .
    Post edited by Alpha Channel on
    Did you by any chance update your IE to version 11? SMS has a patch for P9 and up but isn't providing one for anything lower.
    Also, if the V4 morphs aren't working, try re-initializing the morphs using the .bat file fount in the !DAZ file in the library folder. I found that sometimes with multiple versions of Poser on a system, you need to re-initialize. Especially if you are going from one version to another.
    Easiest way I found was to launch the version I was going to use (I'm a beta tester so I need multiple versions) and then close it. Run the .bat file and the ExP morphs initialize to the last version of Poser that has been opened. After the .bat file runs, reload Poser and then your V4. This should fix the problem.
    What OS are you using?
    Hi icprncss, aye I inadvertently 'upgraded' to IE11 which promptly killed the access to the Library (Flash, why Smith Micro?... Why?), the Poser 9 3.1sr completely kills Poser 9 on my system, it just doesn't start with it applied (and I'm running Win7 Pro).
    To be honest this is the first time I've fired up P8 or P6 for months, I have however run the .bat file as you've suggested and it works a treat I've now got two pregnant V4's to call upon, that makes for one happy Tech support and hopefully one happy student. :-) .
    Microsoft has issued a fix for IE 11, which stops your PC automatically updating to it.
    http://www.microsoft.com/en-gb/download/details.aspx?id=40722
  • TaozTaoz Posts: 10,005
    edited January 2014
    V4 Morphs++ have one under Lower Torso. Here it's dialed to 0,768, it goes up to 1,200 (Poser).
    http://www.daz3d.com/victoria-4-2-morphs
    656 x 850 - 21K
    Post edited by Taoz on
    I must've been dialler blind, couldn't see it for love nor money, I knew V3 had a dial for it and I could've sworn blind that I had seen one for V4 (the ol' can't see the wood for the trees). That makes it three then, if nothing else more options are better.
