G8F's teeth became rounded som…
Daz 3D Forums > General > The Commons>G8F's teeth became rounded som…
G8F's teeth became rounded somehow...
in The Commons
My G8F character's teeth suddenly became rounded abd spaced for no apparent reason, and I can't seem to recover the G8F default. Odd! Anyone else experience this? What's the remedy?
Thanks!
Did you install a new G8F character recently?
Don't know the answer for sure, but subdividing things tends to round them and make them smaller, perhaps that could have happened to the teeth somehow?
I'd go through all my face shape and pose morphs to see if they are zeroed.
Do you have Mouth Realism HD morph turned on? It seems to round the teeth a little bit
Usually when that happens, the character was save wrong, and it double applies mouth realism HD if I remember right.
I have this problem all the time especially in Blender. Usually, it's from Subdivision. I've also found that sometimes using a Character's Full Body Morph + Any Other Smoothing or Head Morph can amplify the problem. Unfortunately, I don't know a DAZ solution, but those are the conditions I've noticed. In Blender, I can mask the smoothing in a way. One other adjustment is to use the Teeth Morph to reduce the gap since that makes it less noticeable.... slightly...
Probably a morph has been saved improperly. I find it tends to effect teeth and eyes the most.
