Any tutorials for making sparkly materials.
WilmapWilmap Posts: 2,917
Are there any good tutorials to help me make a sparkly texture for an item of clothing I'm making, please?
I think I need to use specular, but not too sure on how to go about this.
  • TotteTotte Posts: 14,136
    I would use a specular maps and a reflection maps with small spots of white on almost black.
    I just have to give it a try...
    730 x 682 - 39K
    600 x 600 - 40K
    I must admit for my textures I very often make a dedicated reflection map, but then I use Poser, not sure if this would work in DS.
    You can use environment maps for reflections in DS, but I tend to dislike that as they reflections often comes out unnaturally bright, specially in darker renders. I like raytraced reflections, I know it's much slower but the results are so much better. Hang on, example coming up..
    Raytrace vs. Reflectionmap. The only changes to the one on the left is that all reflectionmaps were removed.
    1200 x 960 - 142K
  • WilmapWilmap Posts: 2,917
    Thank you both for the info.
    I'm trying to make something that looks like sparkly ice, but for fabric, if you know what I mean.
  • scorpioscorpio Posts: 8,508
    Have u tried the AOA SSS shader it has a sugar setting which kind of sparkles.
    Is this the sort of thing you are looking to get.
    848 x 1200 - 162K
    Yes something similar to that.:-)
    Sorry didn't get any notifications.
    That's done using AoA SSS Shader, with sugar setting and ambient set. I also set the SSS Material Type to Spectralon.
    Theres a map on the skirt in the diffuse and reflection strength but it works with out one.
