Rendering black drow skin in DS?
MalandarMalandar Posts: 776
Anyone know what settings I need to play with to get Daio's V4 drow to render well in DS? I know she released a light set for it but the ones I have are poser lights and they don't work in DS4.
I need to get it rendered so that you can see the details of her body, right now you can see her nails her outline and her eyes and thats it.
  • CzexanaCzexana Posts: 167
    Looking at the product images the skin appears quite glossy, so you'll need strong specular lighting I think.
    One thing you could try is to add some velvet, using the UberSurface or HSS - that might bring out the edges better. Just rember to copy the surface settings, apply the base shader then paste the settings back in (I can't remember who on the old forum first mentioned that, but it's worth repeating!) then apply the velvet to taste.
  • JaderailJaderail Posts: 0
    Drows are more blueish than black see.
    100 x 100 - 9K
  • NeilV_1NeilV_1 Posts: 442
    I have to agree with Jaderail
    set your Glossiness to around 65 %
    I would put the specular colour to a light grey say 192.192.192 at around 25 to 35 % depending on your lights
    myself I would add a a tough of blue to the ambient channel 0.64.128 at 10% (this one is a personal option again you may need to play with the hue of blue depending on the lights)
    if it comes with a bump map you need to adjust so that you can see the bump ( I tend to do this without the diffuse map applied to make seeing this easer)
    for lighting model use metallic or plastic depending on the type of effect you are after don't use skin as this adds a pink tone to the surface that you will have to compensate for.
    as suggested above you can also add uber surface for more advance settings as well this image below use Uber surface and as you can see the skin is more blue than black ( This is shadow kin for M5)
    900 x 1200 - 411K
  • FistyFisty Posts: 3,416
    Agree with the previous post with the exception of metallic lighting model.. since the skin is black (not grey, black), metallic lighting model will effectively make it matte. Plastic is probably your best bet. that's if you want to use regular surfaces.
    To get best results use uber surface (my library/shader presets/omni freaker/uber surface or there abouts, hold down control key and double click apply uber surface base - when the little box pops up chose all surface and ignore)
    Turn bump back on, you'll need to adjust the strength later. Turn specular 1 on if it's off, try color white or light blue, strength about 15%, Glossiness about 8, and sharpness 0. Go down to velvet and turn it on, color white, strength to taste - try like 40% to start, adjust falloff to taste, smaller numbers make more effect. (that will defign the edges of the figure for you)
  • edited December 1969
    @Fisty: Your UberSurface instructions worked fantastically with Dokk Alfar for M4. I'm terribly pleased that I can now render drow in dark places... you know, like the places one usually finds drow... (Because oh, look, black skin in the dark! That's not a lighting nightmare... ... anymore!)
    600 x 900 - 961K
    woot woot! =)
  • riftwitchriftwitch Posts: 1,405
    That's great! I can believe I'm looking at someone with black skin; not blue-gray, dark purple, or any of the other colors I've seen in artwork, but black. Like the gamebooks and novels describe them. I'll have to give Fisty's tips a try the next time I'm doing a dark elf render.
