How to reset render setting to default?
Hi,
Is there a simple way to reset render setting to default or do I have to do it manually all parameters one by one?
  • Catherine3678abCatherine3678ab Posts: 8,454
    edited June 2020
    Xellosz said:
    Hi,
    Push the Defaults button ;-)
    707 x 512 - 63K
    Post edited by Catherine3678ab on
  • XelloszXellosz Posts: 855
    edited June 2020
    Xellosz said:
    Hi,
    yes   Sometimes you don't see what's before your nose.
    Thx.
    Post edited by Xellosz on
    You're welcome ;-)
  • D'oh!
  • CenobiteCenobite Posts: 206
    You can also set things back to Factory Settings under Edit / Preferences then select the interface tab at the bottom is Reset To Factory Settings, this is handy if you have done something stupid and can't figure out what it is you have done.
