3D OBJ Shoe file - Add onto Ge…
Daz 3D Forums > Software > Daz Studio Discussion>3D OBJ Shoe file - Add onto Ge…
3D OBJ Shoe file - Add onto Genesis 8 female
i have an obj file of some converse shoes that i want to import onto the genesis 8 model before i change her pose, but im struggling to figure out how to 'link the shoes to the figure' so that the shoes move with the body when i edit the pose. is this possible? Thanks!
Is it one file for the whole pair of shoes or do you have separate files for each shoe?
currently the OBJ file is both shoes in one file. i tried to follow some steps i found online by rigging the obj and fitting it to the figure but the outcome was not correct - see attached photo.
when i move the legs now, the shoes move with the legs, but unfortunatley, the shoes are not in the correct positition, even thought i postitioned these in the correct place before fitting.
Right, they really need to be correctly placed to fit the base figure in its zero pose. The first thing you need to do is split the shoes into separate OBJ files, somethign you can do in DS itself fairly easily:
The reload the original, two-shoe OBJ and do the same to get the other foot.
Import both shoes and load the base figure, then
Now if you reimport that OBJ you should have a version with both shoes aligned with the base figure, and the Transfer utility should give the desired result.
thanks
Hi Richard,
i followed the above instructions and was able to fit the shoes to the genesis model thanks!
i exported the model in T-pose as an obj file so that i could import into Clo3d. i then set the genesis model in daz3d in a new pose, saved again as a obj and imported as a morph target into clo3d to change the pose automatically. however as you can see from the below photo, one shoe is darker than the other. i cannot understand why this is? do you know what could be wrong? is it daz or clo?
