Villager Clothes for MFD
MJ007MJ007 Posts: 1,684
Hello all,
I am interested in this set, however I only own the MFD and was wondering how does it look with just that?
Can someone please post a render of this texture set on a MFD only?
Thanks in advance.
-MJ
  • luci45luci45 Posts: 2,777
    Here it is. Looks bad around the collar, would have to fix the trans map. Also there's a gap between elbow ruffles and sleeve on red dress.
    1400 x 1050 - 250K
  • thd777thd777 Posts: 943
    edited November 2014
    The image from Luci45 uses the sleeves, corset and collar from the expansion pack. Here is a quick shot of just the dress.
    Ciao
    TD
    600 x 900 - 565K
    600 x 900 - 559K
    Post edited by thd777 on
  • MJ007MJ007 Posts: 1,684
    Perfect! Thanks!
    -MJ
    Do u think this could pass for 18th Century attire for field hands?
    -MJ
    -MJ
    The brown one, yes. The red one not so much as red color dye was very expensive and usually reserved for royalty and the wealthy.
    Ciao
    TD
    Gotcha. Thanks again.
    -MJ
    One last question... is it possible to make the brown one short sleeved like the red one?
    -MJ
  • Jonathan BJonathan B Posts: 114
    -MJ
    Taking a quick look at the Snow Sultan template/seam guide for the MFD, (http://www.snowsultan.com/seams/mega_mfdseam.gif), it does not appear that there are separate material zones on the sleeves. You would probably need to make a transmap to shorten the sleeve length.
    Post edited by Jonathan B on
  • FistyFisty Posts: 3,416
    could probably use the transmap from the red one on the brown one easily enough
