Strand-based hair not visible …
Daz 3D Forums > General > Technical Help (nuts n bolts)>Strand-based hair not visible …
Strand-based hair not visible in render or viewport in DazStudio 4.15
I know there are already a few threads about this, but none of them have helped so far.
When trying to use the strand-based hair tool, I can view the guide hairs in the viewport but the model is bald in the render. The model is also bald when using preview PR hairs. Some of the fixes I've tried so far:
- Make sure that the geometry edit tool is not selected.
- Increase Render Line Tesselation Sides until the hair appears.
- Unparent the hair from the model and use the "Fit To" option instead.
None of these have helped. How can I get the hair to show up?
Is it an actual render and not Iray preview?
Ad 1) also includes Mesh Grabber if you have that.
Do you have other strandbased hair and have you tried that?
Which hair are we talking about?
I assume it's actual render, pressing Ctrl+R.
I'm on the node selection tool when rendering, but I've tried every tool.
I'm using the "Create new strand-based hair" option that comes with DazStudio.
After the creation, have you then painted where you want the hair to be?
Painting the head is part of the creation process, right? You choose the visible areas -> paint where to grow -> distribution/density -> comb/style -> clumping -> tweaking.
Like I said, the style curves are visible in the viewport so it looks like it's good to go but the actual hairs don't show up.
Don't know if you ever found an answer to this, but I found that parenting the hairs to the head makes them invisible. If you change parent to none, they show up in rendering.
Hi Plimfelt,
In SBH Editor:
Once you create SBH and click OK in editor.
Once in Daz:
PARAMETERS TAB
Select SBH in scene and find Misc, click fit to and select your Genesis model .....Move model head and undo move and you should have SBH fit your figure.
NEXT
Still in PARAMETERS - Find LINE TESELLATION and turn on PREVIEW PR HAIRS. Yellow curves will now turn white.
NEXT
Go to SURFACES - Select SBH and look for viewport color(which is white), choose a color and hair should be viewable in Viewport
NEXT
To change hair color for rendering - select ROOT TRASMISSION/TIP TRANSMMISSON (which is just under viewport color) choose your hair color.
NEXT
Go to HAIR ROOT COLOR/HAIR TIP COLOR and choose chosen hair color.
NEXT
You could leave and go back to viewport and RENDER to check hair coloring .......OR you could play around with HAIR ROOT HIGHLIGHTS/HAIR TIP HIGHLIGHTS but is not essential.
Good luck!
