Export Blender Clothing and Im…
Daz 3D Forums > 3rd Party Software > Blender Discussion>Export Blender Clothing and Im…
Export Blender Clothing and Import into DAZ
Hi, I'm having problems exporting clothing from Blender to Daz.
In Blender I have a plane which I've created a tanktop from.
Now when simulated it falls nice over the figure.
Then I export this to an .obj file.
When I import it in Daz I do see the tanktop (way larger), but I cannot fit it to my Genesis 8.
Even with the Transfer utlity it won't fit to my genesis.
Does anyone suspects what this could be? Or have a solid tutorial on exporting this to Daz?
Thanks in advance.
When export from blender / import to DS you must be aware that they have a difference in scale of 100. I import into DS witk scale 10000%. And the XYZ axis are different, so you have to take care of that too under export or import.
That said. What is it you are experiencing in DS?
If you exported a figure to use as a guide in Blender make sure you use the same preset in the options dialogue for both export and import, otherwise the scales may not match or the alignment may be different (e.g. the clothing might be laying flat on the ground).
The Transfer Utility ignores any adjustments made with the DS transforms, it just goes for the zeroed properties of the target object - if it's too large than that will be how it fits.
