Retro Question - for V4/M4 etc, what utility replaced PhilC's Wardrobe Wizard?
DiomedeDiomede Posts: 15,264
Old school question.  Transfer Utility does not seem to work with V4 generation
I have cause to use figures from the V4/M4 generation.  In the past, if I had an existing conforming clothing prop that lacked some of the morphs, I could use Wardrobe Wizard inside Poser to inject the morphs into the clothing.  WW also worked if I made some mesh clothing for the V4/M4 generation, or any figure that you bought access to.  I could use Poser's Wardrobe Wizard to convert the mesh to conforming clothing and insert the morphs of the figure.  But somewhere along the line, Poser dropped Wardrobe Wizard (my updated version doesn't have it, and I hadn't used Poser in a long time so didn't notice).
So, is there a utility inside Daz Studio that will act like the transfer utility for the V4/M4 generation - or is there a button in the transfer utility that will allow use for older figures?
Alternatively, did some function in Poser replace the wardrobe wizard and just have a different name?  Or maybe wardrobe wizard is still there and I just can't find it?
Or, maybe there is a plugin or utility that can be acquired that does the same function?
