Shader advice/help please
IkyotoIkyoto Posts: 1,159
edited March 2015 in The Commons
Any shader advice for room temp/runny yogurt? I need thick gels for some sci-fi stuff and post work only goes so far. Sticky slop drips do cast somewhat of a shadow.
The first image on a google search of "flax seed gel" is close, but a touch too thick, but livable. I'd like it in glowing blue ( high ambiance).
Post edited by Ikyoto on
    Which renderer?
    If it's for 3Delight and Studio, then...Dimension Theory's Goop set for the AoA subsurface shader is probably what you are after...
    http://www.daz3d.com/subsurface-goop-shaders
  • IkyotoIkyoto Posts: 1,159
    mjc1016 said:
    Which renderer?
    I've got goop, but unsure of how to change the colors to get a "neo coming up out of the gell" look.
    I need it be this, but a little bluer.
    http://www.chud.com/wp-content/uploads/2011/07/MatrixStills__0001_Screen-shot-2011-07-29-at-12.21.06-PM.png.jpg
    edited March 2015
    I don't have Goop, but I would imagine that since it is on the base SSS shader that tweaking the subsurface color and scale is where to start.
    The only thing changed between the two renders is the subsurface color
    1024 x 819 - 694K
    1024 x 819 - 700K
    Post edited by mjc1016 on
    I still got a lot pf work to do, but I've gotten some good leads here. Does anyone know of a good tutorial for sss? I also would like to do blood splatters/containers. Any good blood shaders?
    Blood splatter props: http://www.daz3d.com/add-on-for-zombie
    Well, with my wife being a nurse, her comments on all the blood shaders both available for artists use, in DS and any used in movies (if they just don't use gallons of the fake stuff) are..."Nope, not even close."
    But, in Fisty's Liquids, from a couple of Christmases ago, there's a blood...
    http://blackraven3d.com/sponsored/fisty/freebies/
    The Fisty's Liquid Updated is the one to get.
  • Oso3DOso3D Posts: 15,040
    One thing I suggest, with 3Delight and SSS to get really strong effects, is shutting off the 100% limitation in parameter options, and crank that sucker up to 200+%.
  • NovicaNovica Posts: 23,904
    This might be way off base, but wasn't there a product in the store that was honey? If the color and opacity settings were tweaked, could that look like runny yogurt?
    Blood splatter props: http://www.daz3d.com/add-on-for-zombieI FORGOT I HAD THAT! OUTSTANDING! HOO RAH! THANK YOU!THANK YOU!THANK YOU!
    Sadly, it was poser only for the mats, but the objs work for a lot of stuff.
    Having a family of nurses, and having worked in a hospital (ok it was the morgue), I'll take her word over most others. Nurse do the real work, doctor's just get the kudos.
    Thank you
    edited March 2015
    Raw test image
    That Zombie add-on pack is way cool!
    1410 x 600 - 43K
    You're welcome, I see you've put it to good use too :-)
  • chris-2599934chris-2599934 Posts: 1,834
    edited March 2015
    For blood splats, try the "10 3D Blood Props" at this page:
    http://squickism.com/misc/downloads/index.html
    Can't vouch for their realism, but you may find them useful.
    P.S. Note that there's other content elsewhere on that site that's... well... what one might expect from somebody offering free blood splat props.
    Post edited by chris-2599934 on
