Genesis 8 to Genesis 3 Pose Converter?
nabob21nabob21 Posts: 1,004
Hello,
I am aware of pose converters that go from Genesis 3 to Genesis 8 but is there a converter that goes the other way? From Genesis 8 to Genesis 3?
Thanks in advance for any replies.
nabob21
  • richardandtracyrichardandtracy Posts: 5,749
    edited June 2022
    There is a little script that can modify the pose after the event.
    If you download DavidGB's 'G3 G8 Pose Adjust Scripts' from Renderosity. In that there are 3 scripts. Open the 'G3F G8F Pose Adjust - Full.dsa' script in notepad or a similar text editor. Then everywhere it says something like:
    ( nZRot + 6 )
    change the + sign to a - sign and everywhere it says something like
    ( nZRot - 6 )
    change the - sign to a + sign (total 2 places for the + sign and 2 places for the - sign) and save the file as 'G8F G3F Pose Adjust - Full.dsa' and then you have created your own adjustment script.
    I can't attach the edited script as it's DavidGB's copyright. The script change is as simple as that. This script does limbs, but not expressions or things like finger grasp sliders. It's usually enough, though.
    Regards,
    Richard.
    Post edited by richardandtracy on
  • SevrinSevrin Posts: 6,309
  • NewGuyNewGuy Posts: 211
    Also this one has scripts for it too:  https://www.daz3d.com/ultimate-pose-mixer
  • nabob21nabob21 Posts: 1,004
    Thank you everyone for the help.
  • stefan.humsstefan.hums Posts: 132
    Converting the poses is not even necessary. On Renderosity, search for the user ArchangelFirewolf, he has 4 freebies which make it possible to use G8 poses on G3 and vice versa - without converting them first. And the poses are adjustable, you get some sliders for that in Parameters -> Pose Control.
    Thanks stefan.hums.
    Yeah, I only use the "Pose Correctors" for switching between 8 and 3.  Converting just takes up space for nothing.
  • RiverSoft ArtRiverSoft Art Posts: 6,608
    If you have Bone Doctor, it also has scripts for G8 to G3 pose conversion.
    Thanks RiverSoftArt and Sevrin for the suggestions.
  • mdingmding Posts: 1,249
    At sharecg there is the "Daz3d Pose Converter (Standalone)" (freebee) which batch converts poses between G, G2, G3, G8 (up and down).
  • marcelle19marcelle19 Posts: 172
    edited March 2023
    Thank you.
    Post edited by marcelle19 on
  • Charlie JudgeCharlie Judge Posts: 12,810
    edited March 2023
    marcelle19 said:
    Thank you.
    Don't search vendor; search freestuff instead.
     https://www.renderosity.com/search/freestuff?keyword=ArchangelFirewolf
    Post edited by Charlie Judge on
