Genesis 2 Female Not Loading
PAWN_EDMPAWN_EDM Posts: 55
edited July 2022 in Daz Studio Discussion
I usually work with Genesis 8 but I had a pose product for G2F and was going to use a script to convert it to G8F. I didn't have the G2 starter essentials installed (although the smart content tab did show the product just without any asset thumbnails. Likewise, it was not under the install tab) so I installed it via DazCentral. The thumbnails popped up in the smart content and the Genesis 2 Female and Male folders showed up in the regular content tab. The only problem was that Genesis 2 Base Female did not load, nor did its male counterpart. I then uninstalled and reinstalled G2 essentials via DazCentral but the same thing happened. Then I decided to try Install Manager. I selected Genesis 2 Starter Essentials Female and Male (nothing else) from the download tab (which made me excited that I was actually getting somewhere) and installed them but it still didn't work.
Just for clarity, I manually installed the pose set before installing G2 essentials. I don't know if this is why it's broken.
What I believe to be relevant log file info is below:
2022-07-27 11:20:55.095 [INFO] :: Loading Layout: C:/Users/▮▮▮▮▮▮▮/AppData/Roaming/DAZ 3D/Studio4/layout.dsx
2022-07-27 11:20:55.376 [WARNING] :: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
2022-07-27 11:20:55.376 [INFO] :: Metadata update succeeded.
2022-07-27 11:21:40.091 [INFO] :: Could not open file : /People/Genesis 2 Female/Genesis 2 Base Female.duf
File does not exist.
1920 x 1030 - 594K
Post edited by PAWN_EDM on
  • PAWN_EDMPAWN_EDM Posts: 55
    New Info!
    I just found out now that DazCentral for whatever reason is stopping the installation at 50%. I don't know if this was happening before and I don't know how to fix it.
  • felisfelis Posts: 4,835
    I would suggest you attach the log file with the full description of the error.
    Have you tried to install it from inside Daz Studio - not a recommendation, but a question?
    I've tried installing it directly in Studio but it's not in the install tab.
    I will edit my post with the log file info
    That was my suspicion.
    Try to rightclick in Daz Studio and select uninstall
    If it is installed from inside Daz Studio (Connect), it will override any other installations, even if the Connect one doesn't work.
    Thanks I'll try that
    IT WORKED TYSM!
