ZBrush Error send to Daz3D (Goz)
Hi all, i have a problem with Zbrush when i send  material in Goz to Daz3D
the Version Goz is 4.21+(mac 64bit) and Zbrush 2021.1.1
this is the error:
Translated Report (Full Report Below)
Process:               GoZBrushToDAZStudio [1235]
Path:                  /Users/Shared/*/GoZBrushToDAZStudio.app/Contents/MacOS/GoZBrushToDAZStudio
Identifier:            com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0
Version:               1.0 (1)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-12-11 22:14:04.7981 +0100
OS Version:            macOS 12.6.1 (21G217)
Report Version:        12
Bridge OS Version:     7.0 (20P420)
Anonymous UUID:        563C0F07-0F56-B9E5-88BF-17677ECE12B6
Time Awake Since Boot: 1600 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace DYLD, Code 1 Library missing
Library not loaded: '@rpath/libdzcore.dylib'
Referenced from: '/Users/Shared/*/GoZBrushToDAZStudio.app/Contents/MacOS/GoZBrushToDAZStudio'
Reason: tried: '' (no such file), '' (no such file), '' (no such file), '' (no such file)
(terminated at launch; ignore backtrace)
Thread 0 Crashed:
0   dyld                                     0x1025df98e __abort_with_payload + 10
1   dyld                                     0x1025f5a72 abort_with_payload_wrapper_internal + 80
2   dyld                                     0x1025f5aa4 abort_with_payload + 9
3   dyld                                     0x1025a3699 dyld4::halt(char const*) + 615
4   dyld                                     0x10259f5b5 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 3995
5   dyld                                     0x10259e4e4 start + 388
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000002000209  rbx: 0x0000000000000000  rcx: 0x00007ff7bfefe538  rdx: 0x00007ff7bfefe9a0
  rdi: 0x0000000000000006  rsi: 0x0000000000000001  rbp: 0x00007ff7bfefe580  rsp: 0x00007ff7bfefe538
   r8: 0x00007ff7bfefe5a0   r9: 0x0000000000000000  r10: 0x0000000000000092  r11: 0x0000000000000246
  r12: 0x0000000000000092  r13: 0x00007ff7bfefe9a0  r14: 0x0000000000000001  r15: 0x0000000000000006
  rip: 0x00000001025df98e  rfl: 0x0000000000000246  cr2: 0x00000001025a5da4
Logical CPU:     0
Error Code:      0x02000209
Trap Number:     133
Binary Images:
       0x102599000 -        0x102604fff dyld (*) <7b87a986-a153-33c4-8470-d56410b7f9d5> /usr/lib/dyld
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=668K resident=0K(0%) swapped_out_or_unallocated=668K(100%)
Writable regions: Total=9220K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9220K(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
STACK GUARD                       56.0M        1
Stack                             8192K        1
VM_ALLOCATE                         12K        3
__DATA                              20K        2
__DATA_CONST                        80K        1
__LINKEDIT                         220K        3
__TEXT                             460K        2
dyld private memory               1024K        1
TOTAL                             65.8M       14
Full Report
{"app_name":"GoZBrushToDAZStudio","timestamp":"2022-12-11 22:14:04.00 +0100","app_version":"1.0","slice_uuid":"f14a8923-3df4-513b-884d-4ff0b6d3e6f8","build_version":"1","platform":1,"bundleID":"com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.6.1 (21G217)","incident_id":"0DAEEED4-365C-4237-911C-FC062535142C","name":"GoZBrushToDAZStudio"}
  "uptime" : 1600,
  "procLaunch" : "2022-12-11 22:14:04.7922 +0100",
  "procRole" : "Default",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro15,3",
  "procStartAbsTime" : 1693348669261,
  "coalitionID" : 1212,
  "osVersion" : {
    "train" : "macOS 12.6.1",
    "build" : "21G217",
    "releaseType" : "User"
  "captureTime" : "2022-12-11 22:14:04.7981 +0100",
  "incident" : "0DAEEED4-365C-4237-911C-FC062535142C",
  "bug_type" : "309",
  "pid" : 1235,
  "procExitAbsTime" : 1693354364134,
  "cpuType" : "X86-64",
  "procName" : "GoZBrushToDAZStudio",
  "procPath" : "\/Users\/Shared\/*\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/GoZBrushToDAZStudio",
  "bundleInfo" : {"CFBundleShortVersionString":"1.0","CFBundleVersion":"1","CFBundleIdentifier":"com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0"},
  "storeInfo" : {"deviceIdentifierForVendor":"C7610CD2-DA6D-549C-8067-C769A9160187","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0",
  "crashReporterKey" : "563C0F07-0F56-B9E5-88BF-17677ECE12B6",
  "bridgeVersion" : {"build":"20P420","train":"7.0"},
  "sip" : "enabled",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
  "termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: '@rpath\/libdzcore.dylib'","Referenced from: '\/Users\/Shared\/*\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/GoZBrushToDAZStudio'","Reason: tried: '' (no such file), '' (no such file), '' (no such file), '' (no such file)"]},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":25854,"threadState":{"r13":{"value":140702053820832},"rax":{"value":33554953},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":1},"r8":{"value":140702053819808},"cr2":{"value":4334443940},"rdx":{"value":140702053820832},"r10":{"value":146},"r9":{"value":0},"r15":{"value":6},"rbx":{"value":0},"trap":{"value":133},"err":{"value":33554953},"r11":{"value":582},"rip":{"value":4334680462,"matchesCrashFrame":1},"rbp":{"value":140702053819776},"rsp":{"value":140702053819704},"r12":{"value":146},"rcx":{"value":140702053819704},"flavor":"x86_THREAD_STATE","rdi":{"value":6}},"frames":[{"imageOffset":289166,"symbol":"__abort_with_payload","symbolLocation":10,"imageIndex":0},{"imageOffset":379506,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":379556,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":0},{"imageOffset":42649,"symbol":"dyld4::halt(char const*)","symbolLocation":615,"imageIndex":0},{"imageOffset":26037,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":3995,"imageIndex":0},{"imageOffset":21732,"symbol":"start","symbolLocation":388,"imageIndex":0}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4334391296,
    "size" : 442368,
    "uuid" : "7b87a986-a153-33c4-8470-d56410b7f9d5",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
  "sharedCache" : {
  "base" : 140703615672320,
  "size" : 19331678208,
  "uuid" : "57de9b7b-39b3-3557-8aed-37ac450fa1f3"
  "vmSummary" : "ReadOnly portion of Libraries: Total=668K resident=0K(0%) swapped_out_or_unallocated=668K(100%)\nWritable regions: Total=9220K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9220K(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nSTACK GUARD                       56.0M        1 \nStack                             8192K        1 \nVM_ALLOCATE                         12K        3 \n__DATA                              20K        2 \n__DATA_CONST                        80K        1 \n__LINKEDIT                         220K        3 \n__TEXT                             460K        2 \ndyld private memory               1024K        1 \n===========                     =======  ======= \nTOTAL                             65.8M       14 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "61301e3a61217b3110231469",
      "factorPackIds" : {
        "SIRI_FIND_MY_CONFIGURATION_FILES" : "6348493aa52bb16adc4e4d06"
      "deploymentId" : 240000023
      "rolloutId" : "60356660bbe37970735c5624",
      "factorPackIds" : {
      "deploymentId" : 240000027
  "experiments" : [
Model: MacBookPro15,3, BootROM 1916.40.8.0.0 (iBridge: 20.16.420.0.0,0), 8 processors, 8-Core Intel Core i9, 2,3 GHz, 32 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: Radeon Pro Vega 20, Radeon Pro Vega 20, PCIe, 4 GB
Display: Color LCD, 2880 x 1800 Retina, Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2400 MHz, Micron, 16ATS2G64HZ-2G6B1
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB Optical Mouse
USB Device: T2Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 47.5
Pls Help me
  • This looks suspicious: Identifier:            com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0
    What can I do?
    What can I do?
    I am told that that has been there all along and is not playing a part in your issue. You probably need to open a support ticket. In the meantime you can use OBJ export/import (or Morph Loader) to go to and return from ZBrush - the modo preset seems to work.
  • sp.creartsp.creart Posts: 0
    edited December 2022
    What can I do?
    Yes, exporting and importing .Obj files I have no problem, but I can't change the pose of my subject after the modifications on Zbrush in Daz3D ;( .
    While why does Zbrush Goz on Photoshop work !?
  • The ZBrush and Phortoshop bridges are handling very different data using very different interfaces between the applications.
    ah ok..
    i also tried to uninstall daz and zbrush but still the same error... i'm bored with this error :(
  • I don't use Mac so, my situation may be different. Even so: why not use the latest ZBrush version? Which is 2022.0.7. The upgrade is free so.... I see no reason not to get the latest, also considering the extra features that 2022 provided.
