Working in Daz studio but without a 'GPU'
soreata7armandsoreata7armand Posts: 13
edited April 2023 in Daz Studio Discussion
Hello! I have a problem with the filament render. Daz Studio crashes every time I select a shadow type for my spotlight.
It doesn't crush when I have a directional light with any type of shadow, but when I select deep map shadow or raytraced, on my spotlight, it crushes.
I need help because I don't know what to do. please! Thank you!
My pc has 32gb ram and 13700k cpu. No GPU for the moment, just the intel UHD770 from the cpu.
It happens within the 4.16.03 version as well.
Post edited by soreata7armand on
  • Richard HaseltineRichard Haseltine Posts: 101,869
    The sahdow type applies only to 3Delight anyway, if you are rendering in Iray (which is when Filament makes most sense) then you should not see the option unless you have Show Hidden Properties enabled. Still, it shouldn't crash so please report this as a possible bug if you are using the current version of Daz Studio via a support ticket.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,377
    if using Filament as your renderer try adding and editing stuff especially lights in textured mode then switch back or it won't always update
    this also could be why it crashes
  • Hmm, let me install the latest UHD graphics driver and restart my computer...
  • PadonePadone Posts: 3,742
    I can confirm that it is needed to switch between smooth shaded and filament to force filament to update the lights settings. This is a bug.
    But I have no crashes here switching the shadow types. Using the ryzen apu. So probably updating drivers will fix it for you.
    mine doesn't crash either but I do get a much better result on the Ryzen3 computer with the Vega graphics (crisp shadows albeit a bit harsh and sharp images) than I do on the i7 one with the intel graphics (blocky shadows blurry images)
  • soreata7armandsoreata7armand Posts: 13
    edited May 2023
    Hmm, I have reinstalled the latest UHD graphics driver and restart my computer...
    Okay, now daz studio doesn't respond anymore when switching to filament when a spotlight has a deep shadow map or software
    So, i have a simple scene 1 figure, 1 spotlight and when i hit the filament its all good... until i select a shadow type for my spotlight...
    As I mentioned before, I don't have a gpu. Only the 13700k with the integrated gpu
    edited May 2023
    Here are some pics with my specs, guys!
    So, all good until I set a shadow type for my spotlight when the viewport is on filament...
    What's even stranger, if there is no object in the scene to calculate the shadows, there will be no problem with the light having a shadow type.
    1669 x 795 - 423K
    1674 x 795 - 293K
    1920 x 1080 - 259K
    Intel GPUs can be less than super, so this may just be a limitation. But as I said, you should not be using the shadow type options with Filament or Iray anyway - do please report your issues, but then leave the control alone.
    Yes, I did so! I need shadows for my renders to make them more realistic, you know...
    I don't know why I'm having this problem.
    I have always needed to
    there is the 8 light shadow limitation too
    edited May 2023
    @Richard I believe you are confused, we're talking about the filament viewport here not iray. The default shadow type is none so you need to change it to something to get shadows.
    @Soreata From your specs I see the apu ram is 128 MB that can't possibly work. You need to change it to at least 1 GB, I don't know if you have options in the driver settings or you need to go to bios. My ryzen apu gets 2 GB from the system memory, but I guess intel is more limited.
    621 x 322 - 69K
    Post edited by Padone on
    Im gonna do that right now!
    edited May 2023
    yeah even my intel iGPU has 2GB
    think it can grab as much again virtually
    I was thinking Filament was being used as a semi-preview for Iray rendering.
  • Nope, even after increasing the VRAM, via bios settings, the problem persists!
    Either I did something wrong, and memory was not allocated, or there should be another way to increase it. Like regedit or something...
    I don't have any problem at all when using iray.
    edited May 2023
    You can see the apu vram in the task manager as usual, to check if you did it right. If this doesn't work and your drivers are up to date then I have no more ideas, you may try with a ticket as suggested by Richard.
    482 x 226 - 33K
    Yes, its 15gb but it still happens :( even after a fresh windows installment. I'm so depressed!
    1855 x 841 - 236K
    From your picture it seems the UHD 770 doesn't have an option for dedicated gpu memory and it only has shared memory. A quick search on google didn't provide any useful information. I never used intel graphics so I can't tell, usually you can change the dedicated memory for apus in the bios.
    May be Wendy can help better since she has intel.
    edited May 2023
    not really blush
    mine just works
    it's also a Win7 machine
    the graphics are not great iClone 6 struggles on it for example so I think it might be another factor involved
    the also is a limit as to how much you can have in your scene, big ones have crashed my intel driver as has dforce sims if they explode
    Ultrascatter will crash it if too many instances
    Ultrascenery always will crash it as incompatible
    collapsed instances crash filament
    even on my Win10 with the 2080Ti
    sometimes strandbased hair vanishes during animations
  • Hmm, It seems that I have to buy one of these overexpensive nVidia gpus :(
    Only for iray, not for filament. That is, iray works both with the cpu (without denoiser) and nvidia gpus, while filament works with any modern gpu. Apparently intel has issues, but I can use my ryzen apu just fine for example.
