Can't install on Mac
I think this is a rookie prob, so I'm hoping a more experienced mac user than myself has an obvious answer. I can't install hex 2.5; I get the error :
The directory /Applications/DAZ 3D is not writable by the current user
I have had no problems installing any other DAZ product, using the installer. But hexagon won't use the installer.
1. is it normal that hexagon needs to be manually installed?
2. I have admin privileges as user - is this a permissions problem, and is there a simple fix? I'm on 10.10.5
Thanks in advance - I searched and don't see this question come up a lot.
Not a Mac user so please forgive me if this does not work. Try the manual installer, that's the one I always use with PC version.
Thanks John - I figured it out. It was a rookie problem, but I'll post the answer just in case there are any others as Mac-backwards as me. All I had to do was go to the folder, Right Click on it, select "Get Info" and see that my username only had read privileges. I changed that to read and write, and now I'm rolling.
Can't wait to start haxagoning!
Hi! I've got the "You can’t open the application “Hexagon_2.5.1.79_Mac32” because it may be damaged or incomplete." error. I've bought and downloaded it here: http://www.daz3d.com/downloader/customer/files/prod/4222/
Help me install Hexogon on my Mac, please!
UPD. Remove DAZ 3D and install hexagon again
You can't remove Daz 3d, but you can remove Daz Studio (DS)
Thanks krirobt! I got a same problem as yours, followed your advise and I'm now solved.
