Render Settings for BEST Image Quality?
FauvistFauvist Posts: 2,154
What are the render setting to get the highest quality iray render?
Thanks!
  • FauvistFauvist Posts: 2,154
    I'm assuming vendors nor DAZ uses Photoshop or something to sharpen and enhance the colour of the promo images.  Is that right?
  • Richard HaseltineRichard Haseltine Posts: 104,134
    Overall tonal adjustmentsa re allowed, as is editing things which are not part of the product, but the product should be shownm accurately from the render.
  • IceCrMnIceCrMn Posts: 2,181
    edited June 2024
    Post edited by IceCrMn on
    IceCrMn said:
    these are what I use and get good-great results depending on how well I set up the lights
    Render Settings pane:
    Progressive Rendering:
    Max Samples:100
    Optimization:
    Max Path Length:6
    Max SSS Path Length:4
    Filtering:
    Pixel Filter: Triangle
    Pixel Filter Radius: 0.50
    notes:
    there are no render settings that can fix bad lighting.
    be sure to use a camera that has the Depth of Field ON and setup correctly.
    Your renders look a whole lot better than mine!  Thanks, I'lll try your settings.
    edited June 2024
    With some scenes, I disable the Rendering Quality, set max. time and max samples to 50000 and let it run over night.
  • chevybabe25chevybabe25 Posts: 1,286
    This. I let it render until it looks "cooked".
  • DustRiderDustRider Posts: 2,802
     yes +1
    I definitely wait auntil it looks done. Seldom do reders "complete" in the same time or the same number of itereations.
  • dtrscbrutaldtrscbrutal Posts: 529
    edited June 2024
       Just an FYI. Dropping Max Path Length or Pixel Filter Radius values too low can cause issues.
     Textures, and especially lighting will have a dramatic effect on when and where these issues appear.
    750 x 1950 - 2M
    Post edited by dtrscbrutal on
