Why the water is white?
![coolcool0131_eea6a807](https://secure.gravatar.com/avatar/575d9194371eed254a6c6e2aff46402b?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F575d9194371eed254a6c6e2aff46402b_100.png)
https://www.daz3d.com/liquid-pack what i bought.
i applied the water shader to prop and rendered it. but it didn't work. i don't know why. help me.
![](https://www.daz3d.com/forums/uploads/thumbnails/FileUpload/85/37a9b69f9b856e0b0fa7157f487010.png)
1422 x 805 - 295K
![](https://www.daz3d.com/forums/uploads/thumbnails/FileUpload/00/342578a36372b34193c9df3466ca3d.png)
398 x 939 - 255K
![](https://www.daz3d.com/forums/uploads/thumbnails/FileUpload/36/880f9b3265ad20d8cab8c162a93995.png)
2044 x 1122 - 3M
Post edited by coolcool0131_eea6a807 on
That product was released in 2014, before Iray was added in DS. The shader is likely a custom 3DL shader that Iray doesn't know how to "translate".
You could try selecting the object in the scene pane, then, in the Surfaces panel, apply a different shader.
If I encountered this item, I would start with one of the soapy water shaders in this product: Iray Foam and Bubbles
The shaders might work to make that sea foam look plausible. I've used them a fair amount to depict sea foam or turbulent water. Keep in mind that shaders are not the same as Materials. You apply shaders in the Surfaces panel. Good luck!
