Viewport doesn't show nothing how could i fix this?
I just installed and when i opened  it looks like this
1335 x 596 - 44K
  • felisfelis Posts: 4,165
    In the upper right corner where it says Front View, clcik that and select Perspective View.
    Else you can load an item, then it will show up in any view. It is just that orthogonal view like Front View, the ground plane will only be a line, which you might have clipped away in your screenshot.
    The button left of 'front view' is the drawstyle. It is currently in Filament (a kind of realtime renderer), you might want to switch that to 'Teture Shaded'.
    If you are new you might look at this
    https://www.daz3d.com/community/masterclass
