Discord streaming and zoom in and out matter.
Well, it's a pretty straightforward question, but since I can't find the answer by that, I'm leaving the question here.
Basically, while I'm streaming for someone else on my discord server, every time I make a move or change the screen, the Daz Studio zooms in, showing the viewpoint only and then zooms out, showing the panels, library and so. It's pretty annoying for the ones who are watching the scene and I'm wondering if there's a solution for that.
Thank you very much in advance.
  • Richard HaseltineRichard Haseltine Posts: 104,447
    The application does this, or the streaming display (if ypu can tell the difference)? What key strokes are you using, by default shift F11 enters/leaves Full Screen mode (which shows only the Viewport) - you can see the current keyboard assignmnent, if any, next to the Full Screen mode command in the Window menu.
  • dione2345dione2345 Posts: 1
    edited July 2024
    In the case it's from the viewer perspective, since everything seems to be in order on my extent. I'm not sure if this is a problem on Daz Studio or discord, since I couldn't find anywhere so far.
    This is from the viewer POV, it keeps alternating from this and the one with the panes every time I move the scene, causing disorientation:
    Post edited by dione2345 on
  • MadaMada Posts: 2,030
    You're probably streaming just the active window so discord is shifting the focus to whichever window/tab is active. Test streaming your whole screen instead?
