Studio bridge
I currently have Studio 3.1.2.32, when using the Studio bridge in Bryce 7.1 Pro I still get the message of "DAZ Studio Bridge requires DAZ Studio 3.1.2.23 or higher" How do I get the Studio bridge to work?   Studio was installed after Bryce if that makes a difference.
  • HoroHoro Posts: 10,580
    ladydeath - I have used the Studio bridge with version 2.x, 3.x and 4.x with ryce 5.5, 6.0, 6.1, 6.3, 7.0 and 7.1. If I remember correctly, you have to re-install Bryce so that Studio can see it. If you have made any changes/additions to Bryce since you installed it, these will be over-written when you install anew. Best option rename the folder where Bryce is now installed, create a new folder with the initial name and install Bryce. Studio ought to see it now. If it is ok, delete the folder with the new installed Bryce and rename the other one back as before.
    Example:
    Current Bryce folder: MyBryce rename it to MyOldBryce
    Create a new folder MyBryce and install Bryce again.
    When Studio sees it, delete MyBryce and rename MyOldBryce back to MyBryce
    Hope it helps and works ...
    Though I must add that I very seldom use the bridge. i usually export from Studio as Object (obj) and import it into Bryce.
