HD Nipples and Navels G9 - Hid…
Daz 3D Forums > General > The Commons>HD Nipples and Navels G9 - Hid…
HD Nipples and Navels G9 - Hiding where?
in The Commons
Either I'm completely missing something, or the install isn't right. There are supposed to be icons to load the product in People:Genesis 9: Shapes:Paragon, but there is only options to turn the nipples and navels off.
This working right for anyone? Or is this a mystery product that you have to root around for an hour to figure out how to use?
Maybe searching for Nipples / Navel in the Parameters tab will show you were the morphs loading them are ?
The file list only list the two icons you're speaking about, so it's likely to be controlled by morphs sliders somewhere.
http://docs.daz3d.com/doku.php/public/read_me/index/102602/file_list should show you the shaping parameter locations
From the Read Me that I reviewed before posting:
You can find new icons for loading this product in the following DAZ Studio Folders:
“People:Genesis 9:Shapes:Paragon”
Not so much. Just options to remove the morphs. It's a mystery product that you have to hunt down, and, once you find the dials, have no visual indication outside of rendering to see which style you are dialing in. Unfortunate, since the render results are nice from the limited testing I was able to do last night.
Hey there!
The nipples are in Parameters/Actor/Chest/Feminine/HD Nipples
The navels are in Parameters/Actor/Waist/HD Navels
Hope this helps :)
Hey, they should be found in -
Hope this helps!
Thanks, I did find them. It might be good to update the ReadMe file to reflect this.
careful, you'll poke an eye out.
But it hurts so good...
