Eden's Mouth Fix
Catherine3678abCatherine3678ab Posts: 8,414
edited September 2024 in Freebies
Poor Eden arrived with a bit of a dental issue so until the PA possibly updates the figure with their fix, I made a simple morph which puts the teeth in a better place.
Merge the contents of the data folder in with the "one" existing data folder in your main Content collective for Daz Studio. [i.e. NOT in the program's folders]
It is a good idea to have D/S closed when messing around with the data folder.
IF you have already downloaded my first attempt, it may be deleted - or left as is, suit yourself.
This is the same morph EXCEPT it now WILL automatically dial in with Eden's character :-)
My thanks to barbult  and Crosswind for some pointers :-)
As an added bonus there's also a free "no bangs" morph for the hair Amber. IF you don't want this then simply delete it from the folder before installing the mouth morph. If one dials the morph to the negative value, the bangs will appear out front however it is not good for side views.
Enjoy ;-)
zip
zip
New Mouth Fix for Eden.zip
5M
1616 x 1061 - 793K
1800 x 936 - 924K
1817 x 939 - 1M
Post edited by Catherine3678ab on
  • UnseenUnseen Posts: 665
    Thank you so much! Very useful...
  • You're quite welcome, glad it found a good home ;-)
  • TaozTaoz Posts: 9,981
    Eden says thank you for fixing her teeth.  laugh
    807 x 962 - 1M
    Post edited by Taoz on
    You're most welcome.
    And I did notice the environment too, nice touch ;-)
  • barbultbarbult Posts: 24,916
    @Taoz, great picture!
    Thanks!  Yea, while testing the fix I recalled I had a dental clinic I'd never used so thought why not have some fun with that...
  • Could I be on something special if its not working/showing for me?
    grabbed the zip, dropped /data into my Daz Library folder. reloaded Studio, cant find the morph on Eden.
  • Catherine3678abCatherine3678ab Posts: 8,414
    Did you select her mouth?
    Check installation, there is only "one" data folder:
    \data\DAZ 3D\Genesis 9\Genesis 9 Mouth\Morphs\CEF\Eden_Mouth_Fix
    Shows on the Parameters Tab under Head > People/Feminine
