Movie Maker and iRay
Leo ChenLeo Chen Posts: 697
Is that possible to use Movie Maker with iRay?
  • you should be able to use it in iray.
    But considering this is optimized for 3delight, the results will probably be bad out of the box.
    You'll probabaly have to change light settings, as well as any associated textures.
    and that is of course if you have the 4.6 version, older versions are not compatible.
  • Leo ChenLeo Chen Posts: 697
    Thank you, DrunkMon keyProductions.
    But the rendering output is "complete black"...
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,907
    I actually cannot see how a script based renderer could work unless changes are made to the script, I do not have it to test
    Thank you,fool.
    Movie Maker has its own "Dome".
    Seems crazy, but I've found Virtual Dub to be the better option for compiling animations. It can accept an image sequence, similar to how Daz renders animations, apply filters and sounds and even subtitles if you're that way inclined. It's no Adobe After Effects, but I found it gives you more hands-on tweaks than Movie Maker offers, especially with plugins.
    Leo Chen said:
    Thank you,fool.
    and there in lies half the problem, it is blocking iray sunlight
    you need to make it an emitter or hide it and use the images in the iray dome map
    HOF this is Dreamlight Moviemaker not Microsoft live Moviemaker, two different things
    fool said:
    Leo Chen said:
    Thank you,fool.
    Thank you,fool.
    It is still too complex for me now.
