Autodesk Fusion 360 Free for h…
Daz 3D Forums > General > Freebies>Autodesk Fusion 360 Free for h…
Autodesk Fusion 360 Free for hobbyists
I don't know if this has been mentioned before; but evidently Autodesk is making Fusion 360 available free for hobbyists. Just download the trial then register for the license (1 year renewable)
Scroll about half way down and see the right hand block: http://www.autodesk.com/products/fusion-360/overview
Post edited by Charlie Judge on
I'd like to throw in that it's also legal to use it for commercial purposes as long as projects created with it generate less than $100,000 usd/year revenue.
Thank You, and thanks for additional info, I better get it.
Hey, now! Thank you thank you thank you thank you thank you for finding that! My Student License on AutoCAD/Inventor/Et c. is complete NCU, a waste of time except for the learning-tools themselves...
Awesome. I wonder if it does fluid mechanics as well...
Awesome! Thank you for the heads up! Now I can go shopping for a 3D printer! :)
The cost of sending it to a 3rd party is probably cheaper than buying a 3D printer, if you're only doing a few figures at a time :) Industrial printers also have waaaay higher resolution than most home-use ones.
If you aren't afraid of putting it together yourself, you can order kits from china CHEAP. Same printer kits (RepRap, Rostock, etc.) but a LOT cheaper. As in 'one-third' the price, for the same hardware.
WOOT! That's awesome. For the things I'd like to make, I found CAD to be soooooo much easier than "artistic" modelers. Haven't had decent CAD app since college.
Thanks for the tip. That's probably not a bad idea to start out. I've got a lot to learn anyway!
Now that might be worth trying. Though, if a print comes out funny looking, it'll be hard to tell if it was due to printer or more likely the person who built it!
Any reputable sites or dealers that you've seen?
Just a word of caution before ordering from Chinese websites: the reason why the prices are so cheap is because many products come with little to no QA. That is, there is no guarantee that the product you purchased is actually of the quality that you expect. *Functionally* they may work, but parameters and specifications will be all over the place.
There are, of course, exceptions to this rule but you may have to dig a little further.
Send me a PM and I can direct you to some places...
Lots. Most sell through AliExpress, but there's plenty of variation there. And shipping does take a few weeks. Make sure you look at feedback/orders records and such for any seller you are looking at buying from (I wouldn't recommend buying from anyone on there with less than 100 orders and a positive feedback of less than 97%). And even if the kit is of lower quality, it is a good way to get some experience with 3D printing (and kit assembly!) BEFORE spending a lot on a better one. Also, make sure you are in fact getting what's pictured (read the ad thoroughly) since some of the sellers can be a bit deceptive with the product images..... Something like this is a good deal for a beginner: http://www.aliexpress.com/store/product/2015-Guaranteed-100-DIY-sunhokey-prusa-i3-3d-printer-2-rolls-filament-SD-card-free/1502993_32379090327.html ;
Things to look for: Heated Bed (sometimes it's an upcharge, but not a lot), Auto-levelling (so you don't break nozzles/beds, also sometimes a small upcharge), free shipping
As a beginner, you don't need to spend extra for double or triple nozzles, aluminum frames (though nice if you can afford the extra price), full shrouds, or extra-large bed sizes.
Thanks for the heads up, Charlie Judge and Vaskania.
This is the most intuitive modelling program, I have ever approached - and it has sculpting as well.
Below is a quick Bryce render of the shape I created in Fusion 360, just for testing its different tools.
@mtl1 and @hphoenix
Thanks for the information and the recommendations!
what format did you use to export to Bryce?
it's free for 3 years, which is a lot of time but it still has a clock ticking to when it wont be free.
That is the student license. There is also a "Startup and Hobbyist" license which is valid for one year but as I understand it is renewable.
Edit to add screenshot
About that: how do I switch the NCU "Student" license on my account to a "Startup and Hobbyist" license?
I don't really know but you might try asking on the Autodesk forums: http://forums.autodesk.com/t5/fusion-360/ct-p/1234 or contact Autodesk.
Doesnt Fusion carry it's own licensing apart from your current software? See if this still applies to you. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-activate-start-up-or-educational-licensing-for-Fusion-360.html
I installed it, and found it was already covered in the existing license/login. Unless I'm missing something here.
I even tried uninstalling EVERYTHING Autodesk except the content packs and then reinstalled Fusion clean: still recognized the same user account and no prompts to enter serial numbers.
I'm not sure if will help solve your problem but here is how to do a clean uninstall of Fusion 360:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-uninstall-of-Autodesk-Fusion-360.html
Manual deletion of the appropriate username/appdata files is evidently required in addition to uninstalling the program.
Also you could check under the Help menu to see if there is any option for changing the registration.
Thank you!
I had to set up a new Autodesk account (to preventlicense crossover), but it worked!
Its DRM cloud base software. No thanks. even if it is free , I'll stick with my autodesk student suite
From Fusion 360 I exported the model as .stl, and then opened in Blender and saved as .obj
Then you can open it in Bryce, Daz Studio, Poser and so on.
If you choose units in Fusion 360 as cm, then you will get one to one scale in Daz Studio and Bryce.
It will be really pity, if this startup licence is only valid for one year. I've finally found the modeller, which is really easy to use.
These are the Terms Of Service listed at:
http://www.autodesk.com/company/legal-notices-trademarks/terms-of-service-autodesk360-web-services/autodesk-web-services-entitlements
Startup:If your entitlements have been designated as “Startup, ” You may use the service if You are (i) a company generating less than $100,000 (or equivalent in other currency) per year working on a project or product that is not yet commercially available, (ii) an individual working on a project or product that is not yet commercially available and is generating less than $100,000 (or equivalent in other currency) per year, or (iii) an individual using the service on a personal basis that is not for commercial, professional or for-profit use. The term for Your Startup use will commence on the date access is granted and will end on the earlier of (a) one (1) year from the date of access; (b) the date where the company or product or project generates more than $100,000 per year, or (c) the date of notification to You from Autodesk (which may be provided (1) via email to the registered email address or (2) via notice in the administrator site or account of Your site or account, or (3) via any other manner deemed reasonable by Autodesk which involves specific notification to You (including, for example, by in-service notification functionality)).
What does it really mean?
Simple object made in Fusion 360, exported as .stl, converted to .obj in Blender and rendered in Daz Studio with iray.
Arabella 7 is just for scale comparison.
Enough to stop me going to look.
thanks!
i exported my first """model""" in STL format,
probably should not have chosen the highest resolution/tessellation it came out as 38000 facets
then i imported it in Blender ( so far, the 6 or 7 times i imported STL things in Blender it always went well )
then i exported as an obj
then imported the obj in Daz Studio
then used my mcjBoxUV script to add a workable UV map
rendered in iRay with a normal map
Looks great. Wish there would be the way to automatically UV unwrap any shape.
I always use "Low" settings when save as STL. It is pretty easy to add more polygons with subdivide in Daz Studio.
