Keying everything in 4.12
Daz 3D Forums > General > Technical Help (nuts n bolts)>Keying everything in 4.12
The timeline changed, before I could select everything, hit the keyframe button and it would fix everything (I batch render sequences). It no longer works in the advanced view and the simple view doesn't have a keyframe button, is the a simple way to keyframe everything in 4.12?
In the current General Release you have to expand to show properties, but the chnage log shows that they have added an Intermediate mode which acts like the old Advanced mode and will presumably allow keying just by node selection.
Thanks, where can I find this mode?
It will be in a future release.
I still need a way to fix everything, how do I add keys to everything after expanding to the properties nodes?
perhaps you can burn your timeline to a throw-away aniblock, then bake that aniblock back to studio keyframes?
--ms
Somwhat it seems to work if I right click the Timeline tab to add keys, rather than using the dedicated buttons.
