alpha only image series
I need a matching opacity channel video not image series with alpha for another program, iClone that does not support animated image series.
it needs two avi or other video files one diffuse one opacity mask
Carrara beautifully simultaneously renders me alpha images to accompany my image series but they are NEGATIVE!!!!!
I need white figures on a black backgound!!
is there a way to get it to do the reverse?
none of my video editing programs do negative
yes I know irfanview does but I need this for COMMMERCIAL USE as monetizing on youtube if I can.
and 1000+ frames crashes GIMP as layers so forget THAT idea!
is a simple but perplexing problem!
only way I have done it before is a white shaded figure no shadows on a black background RE-RENDERED again!
at the moment I am trying the png diffuse image series in cinegobs keyer but I want transmapped planes in a scene not a chromakey
doing it in carrara not an option as I am using iClone locked content
GIMP can't convert a batch of images from an image sequence? If it can only handle a certain number of images, you could break the amount up and do the first couple hundred, then the next couple hundred, etc.
Another possibility is Quicktime Pro. It is only $30.00 US and can convert to negative with one of its video filters called X-Ray. Ifd you're trying to monetize your videos, then the old adage may apply: you have to spend money to make money. ;-)
Thx was afraid of that
yes I am being cheap
most PAID video editors would indeed do it!
Find an old version of Vegas Video, they don't run that much and allow alpha channels. My version #3 did it.
Imagemagick would do it, but since it is mostly a command line utility figuring out the commands would be a bit of a headache...unless you can find a script for it
Did you grab HitFilm Express while it was free? It has an INVERT filter.
yes and not looked at it!
good to know!
thumbs up Holly!
Free is good, but if you're monetizing your videos, you could write off the expense of your software a business expense. ;-)
I'm sorry I missed this...
With Carrara, you can save as an sequenced image file, do your edits in whatever software, even running it back through Carrara, using any of its features, via the backdrop. Once your edits are finished, open the finished result in the render room and save it as your avi or whatever format you want.
Carrara can convert any of its outputs to any of the other outputs - the one exception that I know of being an animated gif, which is a one way street, as Carrara won't open the resulting gif. But avi to image sequence, and the other way around works fine - at least in full frames mode it does, which is what I use for renders.
