backing up a hard drive image …
Daz 3D Forums > General > The Commons>backing up a hard drive image …
backing up a hard drive image to an external dive ?
in The Commons
in my old IT days we used Norton. that was over 20 years ago. what the it kids usung these days??
thanks.
I use Acronis True Image. There are a couple of free ones but I haven't had luck with them.
I've used the Acronis True Image "free" version that came with my SSD but it is free because it is customized to only work if you have the manufacturer's brand of SSD in the system. I think I bought an actual copy of Acronis True Image a year or two ago but have never used it. Regardless, the "free" version did a very easy job of cloning my existing hard disk system drive to the new SSD and configuring the system parameters to boot from the new SSD instead of the old drive. But I imagine that copying a hard drive image to an external drive would be done just as easily and quickly. But I haven't actually done that exact thing so why are you still reading my comment?
I used Acronis on my Win XP and Win 7 but it won't work on Win 10 - needs a new version which doesn't come for free. After I deleted all the pre-installed crap that came with my new Win 10 pro laptop, partitioned the HD (left SSD as C:), installed the essential stuff (like Bryce), I created a boot DVD (tools included in Win 10), and then used AOMEI Backupper Standard free to back up my installations on all partitions to a network drive (google "AOMEIBackupperStd" to find the web page).
thanks.
have you successfully restore from acronis?
reading some reviews on it. my pc doesnt have dvd or cd drive. would a restore boot from the bacj up external usb drive?? hopes
if my hd crashed now would be beyond tears. be national day of mourning
I use AOMEI Backupper to regularly clone my drive to my external. I've never had any problems
I use Clonezilla, which is free.
Yes, I've restored from ATI backups many times.
Depends on your computer/BIOS. If you can't boot from a rescue USB drive, ATI can clone a disk, then you just swap it for the dead one.
Use the windows 10 systems image tool for back ups https://www.windowscentral.com/how-make-full-backup-windows-10
or use a cloud service for $80+ a year like carbonite https://www.carbonite.com/
I have Acronis, but prefer for just backups to use EaseUs.
I have a disk image of C drive though, and use Windows own feature for that.
just be aware that write speed might be slow especially if you have an old computer with USB 2.0 ports. I was using my external USB 2.0 hard drive to store backups of my games. I bought a SATA hard drive to store the backups. I spent two days copying files from the external drive to the new internal drive. The transfer rate was around 20 - 25 MB per second. Online games frequemtly update thier files. Obviosly, I'll need to update the game backup files on the external drive often. No way am I going to spend 45 to 90 minutes to backup and restore a computer game. If you have a faster external drive then read and write times should be way faster.
I'm using Image for DOS, a bit nerdy I guess but I've created and restored hundreds of images on multiple PCs without a single error or problem. I has byte for byte verify both on creating and restoring so you can be sure that the restore is exactly as the original disk/partition.
https://www.terabyteunlimited.com/
For people who use backup software other than Windows, such as Acronis True Image, how would you do a system image backup if your operating system failed?
You see, when Windows fails to startup, it gives you some recovery options, like "Startup Repair", "System Restore", or "System Image Recovery". If you choose "System Image Recovery", then you're given an option to load a system image backup from an external drive.
This is a backup created by Windows backup, and I assume Windows can't load a backup created by other software. I also assume you can't run your Acronis software when the operating system is down. So tell me, what do Acronis True Image users do in this case, because it seems such an inconvenience to use backup software other than Windows.
You create a rescue DVD (or USB flash drive if your system can boot from a USB drive) and use that to run ATI. Or if you cloned a drive rather than making a backup, you can just swap that one in.
Image for DOS works independent of the OS, you run it from CD/DVD or USB media. It comes with software that can create such media. So far I've only used CD media myself though.
I done that, i took my main 1TB SSD and secondary 2TB HDD into a place called Phone Doctor a local business that does cell phone data recovery. and they cloned both hards drives cost around $39 for each drive plus cost of the new hard drives.. well worth the money spent and all I do now is every now and then I just update the clone drives with the back-up shadow copy to update the system files specially if add some new hardware. wth as much crap I have loaded it was a great option to get a replica of my system, I bought and brought the new hard drives with me I order online. I keep all my daz content on external HDD drives so those are backed up regularly. Plus when i see hard drives on sale I try get s few to keep on hand just in case i need a another external drive for daz content...lol
