Buy Something That Doesn't Wor…
Daz 3D Forums > Software > Carrara Discussion>Buy Something That Doesn't Wor…
I myself would use the transfer utility on it in DAZ studio and save a support asset
dunno otherwise how well it would import
at that price I grabbed it so can test
Convinced me. I'm buying it too. Not for myself, mind you... for Rosie! :)
after fitting to G8F refit down 'till you get to Genesis 2 and save that one
I don't need to to conform to anyone. I just need to get it into Carrara is all ;)
But I might do as you suggest anyways, just to have it! Thanks so much, Wendy!
So... you tried it on? Is it comfy?
you need to manually download it, DIM fails and no Carrara cannot load it but anything that loads FBX and exports as obj should
I will try DAZ studio itself soon otherwise are lots of free options besides Blender
I'm just going to do as you suggested above. Then I'll just remove the rig in Carrara. Thank you So Much for the Amazing customer support, Wendy! You ROCK!!!
yes it imports into DAZ studio
need to hide bones under visability
on my old PC in D|S4.7 and I haven't got all my clones there
Yep. I got that far, but my conversion down to Genesis failed. I'll get it though! :)
I will try in a few hours on my Win10 with my clones
Catherine made some free ones you can grab
I find converting to prop after dialing up the lower figure clone shape then using TU again actually better than autofit
you get triax that way too
I do use TU, but you lost me on the rest of that sentence. Like, how would I convert it to a prop (in DS), and then dial up lower figure clone shape? I'm definitely missing a lot of this.
in parameters show hidden checked clone shapes
under tab edit/rigging/convert to prop
Wow. Thanks!
Thanks, Wendy!
I've had this in my wishlist for a while as well, not knowing if it would work in Carrara. Too busy to try it at the moment, but thanks for the advice again, Wendy!
I'm getting the big October windows update tonight. Has anyone had any issues with it so far?
if it was the 2004 one it made my Computer laggy but disabling indexing on all my drives has helped enormously
Thanks. I think it is called 20H2.
meh not another one
I apparently don't have 2004 yet, which is strange because I have my computer set to automatic updates, as per instructions from my computer tech.
So, I'm currently updating to 2004, as an interim before even thinking about 20H2.
that took me 15 hours to download and install
You will have to enter all your serials again too
Well, it took my computer about 20 minutes. And I haven't found any products yet that require a serial number reset. All are working fine, including Carrara.
Maybe I got lucky. :)
it reinstalled Windows for me
it said it had to as my version was out of date
Yes, windows was trying to force me to install as well. But I am not out of the woods yet. It is possible that I STILL haven't installed the whole 2004 update, as it apparently has more components that did not download.
I've had no problems but then again I keep my system up to date
well I bought mine last year assuming it was
and had updates enabled
that 2004 still popped up a month ago and told me my operating system was out of date
Same here. My Ryzen just fashes through those updates - done before I get up to go get a cup of coffee, so I just stay seated.
I am so sorry to hear this. :(
I also wish that I could make it better for you
Dog 8 - remember to convert to blended weight.
The figure loads in Carrara and has a convenient shading domain of 'coat' as a base for Carrara hair. However, it needs to be converted to blended weight else the model 'skinning' will not follow the skeleton. Does work once converted to from triax to blended weight in Studio and 'saved as'.
That's great to know!
anyone tried the streets of steampunk? https://www.daz3d.com/the-streets-of-steampunk
any problems like gatwyck or ravenskull had?
seeing it on steep sale. awfully tempted.
its a stonemason set so prolly has uwrap gimmicks.
i might get this instead https://www.daz3d.com/mediterranean-seashore
looks nice and warm
the streetworkers are Carrara (rest Twinmotion) a lot of alpha map chasing up and did use Sparrowhawk's UV unwrap but I do on most duf files
thanks. i guess i'm being seduced by the sale price. showing like 11 bux
cant help but notice none of the doors open in the vid
