How do you save an ACTOR (Char…
Daz 3D Forums > General > The Commons>How do you save an ACTOR (Char…
How do you save an ACTOR (Character) with hair, brows and Anatomical Elements?
Hi Everyone,
Can you tell me how I can save my characters as ACTORS, so I can just merge them into scenes and they load
with their hair, brows and gentialia already attached. Is there a way to do it other than saving them as a Scene Subset?
Post edited by Chohole on
I use scene subset and merge. Is there a reason that this won't work for you?
I also save characters with their hair, brows, sometimes clothing, etc. as a Scene Subset and load them into new scenes. I do this several times a day. Works perfectly.
Lee
Yes, that totally works for me too, but I thought I have purchased characters that are "ACTORS" that load with everything on them.
You know with the little blue actor tab. I was hoping there was a way to do the same thing.
I thought I could create a folder with all my characters as "actors" and not with the little green "subset label." LOL
A character preset can do that, but the post-load script it refers to(which by default just loads the lashes on Genesis 8 figues) needs to ebe dited to handle any other add-ons, it isn't an automated process.
https://www.daz3d.com/forums/discussion/comment/5502206/#Comment_5502206
^^^^^^^ a quick run through on what Richard is refering to.
I always save a scene subset and you can then merge into a scene.
theres a thing in the character preset to post load a script. can mebbe re add the load eyelashes
Thanks, Everyone!
You should be able to load a scene subset without merging into the current scene, given the subset nomenclature - if something is saved as a scene, then there will be a warning dialogue saying the current scene will be cleared.
That warning will only appear if your current scene isn't saved. Many a time I've accidently double-clicked a scene file only for my current scene to close and the new one to open instead of merge. Generally if I'm adding a saved scene I'll right-click merge and delete the things I son't want, like lights, tonemapper options etc. but sometimes I'm half asleep and forget.
Try using the following
File - Save As - Support Asset - Figure/Prop Asset
That saves a completely new figure, not a figure and accessories. So I don’t think that’s what the OP wants to do.
