I just tried installing on my laptop. I do not have Poser on my laptop. So, I created a directory called D:\VWD and installed there. I installed Philemo's bridge (5 files) to my Carrara extensions folder.
First, I got a 'won't load' message when I started Carrara. I'm pretty sure that was a Python error. I installed Python and rebooted.
Now, when I start Carrara there is no error.
I tried a test scene with two simple vertex objects. When I selected an object and clicked 'Go VWD' it asked me to find the VWD program. I did.
Thanks for following up. Great to see you posting, even if it is because I am messing up something simple.
I am attaching the CarraraVWD debug file. Where should I be looking for the Python error file, if any? No error message appeared on the screen, but that doesn't mean much.
It would have been in your Daz Temp folder if there was one, I think.
One thing that wasn't working for me, is that the Daz Temp folder MUST be the default location for VWD to work in Carrara.
I had mine on a different drive and it didn't work. As soon as I put it back to default, Bam!!!
I forgot to tell you that the debug file was reset each time you start Carrara. What you should do is reproduce the error you stated, stop Carrara and pickup the debug file.
My VWD stopped working when my computer crashed and I moved my files from a backup to a new computer. I tried uninstalling and reinstalling. I tried downloading the files again from rendorosity. I tried uninstalling and reinstalling Poser, then uninstalling and reinstalling VWD. Nothing seemed to work so I gave up. That was months ago.
Then today, for no apparent reason, I loaded a default genesis 1, gray shaders and all, and tried VWD on a skirt. And it worked!
It worked on the skirt and genesis above, but I got an error saying the obj does not exist when I tried to use it with a shirt and my Brash figure. Will have to find some of the tips and tricks. Hard to remember some of the details. I remember that one potential problem was long file names. Not sure what the problem is for the shirt here, because it is obvious the model exists.
- Shortening the file names, in this case of the parent object (Brash), worked.
Backward
VWD changed a shader of the shirt, which is strange. The cuffs are gold and the sleeves and torso are red. The VWD process changed the sleeves from red to gold, but not the torso.
been designing a chess set recently to three d print, workflow Carrara then Mexhmixer and blinder to sculp, then Carrara to join up the meshes, then Microsoft 3d Builder (nice little program) - oddly Carrara does a better job putting together complex meshes into one obj. than the fancy doodah 3d builder
anyways, trying to get vwd to work. and failing miserably ... I am using VWD Cloth and Hair - Version 2
could do with some help if anyone knows the answer
I get this error "Index de liste hors limites (1)" - which I think means my horse has stepped over the boundary :)
this is my error log
Thread ID 30928 15 (i) Log subsystem started in elapsed time mode.
Thread ID 30928 15 (i) Logging [debug info (D), info (i), notices (M), warnings (W), errors (Er), fatal errors (!!)]
Thread ID 30928 15 (i) Buffered mode: False
Thread ID 30928 15 (M) Service thread started
Thread ID 30928 359 (i) Temporary rendering context created
Thread ID 30928 359 (M) Getting OpenGL entry points and extension
Thread ID 30928 359 (i) OpenGL rendering context information:
Hi Diomede,
Could you have a look into your Daz tmp directory. There should be a CarraraVWDDebug.txt file which may help.
There also could be a Python_error and/or Python_outpout file which may give more information.
Greetings, Philemo_Carrara!
dunno, mine are all over the place on both computers
and it works or not according to temperament on both
Coucou Philemot !
Yes, it's great to see you, Sir!!!
second that, hope all is well with you Philemo
Hi Diomede,
@Diomede @FENgari @Dartanbeck @WendyLuvsCatz
Thank you for your welcome message.
My life has changed a lot for the pas year and I haven't been having any time for Carrara.
Things are changing again and I'm starting to have more time. You will start to hear from me again :-)
Great to hear Philemo. Your words made my day.
Good news - I hope you are well.
Great to see you posting again.
I believe I had to return my Carrara tmp dir back to its default for VWD to work as well.
Philemo, pleased to see you are well. We were worried for your well being, and happy you are fine and able to rejoin us!
cheers!
--ms
Yes! Welcome Home!!! :)
Thank you for all the replies.
OK, Philemo, I will see if I can recreate the error and then post any updated error log reports.
Q: Anyone upgraded to v2 - I still have v1 - will do some experiments on cloth, still love Carrara's native softbody capabilities and hair dynamics...
I still use V1
it is flakey on my Win10 but works well on my Win7
I can grab the .car files off Win7 for 10 though
LOL Former Selina/Fengari I had to check your threads to find who you were
I still have had more usernames I think
I upgraded. I love it!
V2 has new "Assistant" features that I almost cannot live without. I didn't get very far with V1, but I can't stop using V2!
Here's the Support article for the video
My VWD just started working again!
Woohoo.
Now I have to Remember How to Use VWD!!!!
Error
One step Forward! But one step back.
Forward - VWD found the obj
Backward
Before and after applying VWD to Brash's shirt.
too many polys usually gives me that
VWD dislikes highpoly mesh that Optitex and Dforce loves
Thanks for the tip. For my Brash and Moxie projects, I have control over the density of the mesh, so I should be able to correct such.
Good news !!!
well it seems to have died on my Win7 now too
it works but gets stuck at 52 frames so maybe I can do shorter animations?
cannot send back to Carrara if not done to test
may need to investigate that
pity as D|S Dforce just explodes on the same outfits so obj series imports is not even an option
I may have solved this
VWD creates an "exchange" text file in the same folder you save your scene, for it's settings etc
because I was saving my scenes on a USB drive that I was transfering stuff from over my WiFi all the time to my Win10
(100's of gigabytes of stuff for 2 days at a time!)
I think the bus speed or something was affected and Carrara wasn't seeing the drive
greetings earthlings,
hope everybody is well !!
ps
Greetings back !!!
Sorry don't have VWD but it's on my wishlist.
Hope the surf is good down your way !
you are probably better off using it with Poser at this point
unless Philemo pops in and solves the Win 10 bridge issue
sadly he hasn't been here a year according to his profile, I hope he's OK
thanks Bunyip and Wendy, surf is good, I will try with Poser. :)
New board Bunyip, always makes a man feel ten years younger ;)
Not like that joke,
There's wo old guys hanging around in Taylor's square...
One old bloke scratches his nose, and says to the other: "I feel like a young man again."
"Oh I know, I know," says the other. "...I wish one would walk past."
