HDRI Not Showing in Viewport
Daz 3D Forums > General > New Users>HDRI Not Showing in Viewport
Hello - I've used 3Delight for years but am in the the process of switiching to Iray, which is a learning expereince.
I'm using HRDIs that come with DAZ Studio and one character. I add the HDRI using "envirinment options" in the scene tab and it renders fine, but it does not show up in Viewport. My model is there but the HDRI is not visible. As you can imagine this makes it hard to work with. I can rotate the dome and it changes the background but I can't see it until I render it. Any ideas why this is happening?
If I load Uberenvironment and add an HDRI there I can see it in the Viewport - its just in the "environment options" that I can't.
Any ideas why this could be happening?
Thanks,
Cammy
You could try using the Filament drawstyle, or the nVidia Iray Drawstyle. Those are the only ones which can handle HDRIs in preview.
Thank you so much! I figured there was something I was missing.
