Looking for male gen 8 SHIRT
Daz 3D Forums > General > The Commons>Looking for male gen 8 SHIRT
Hi,
I don't seem to find ANY proper male long sleeves shirt. They are either all tucked in or with short/wrapped sleeves.
Anyone has ANY suggestion? I'm looking for something that is/ can be unbuttoned on the neck. Basically THIS but with long sleeves? I'm desperate T_T
I found this one or this one in the store but again, sleeves are not long. I don't even find anything custom how is this possible? D: Help would be greatly appreciated!
Post edited by ladywolf1 on
Lots of proper long sleeve shirts in the store, but yes most of them are tucked in and modeled in a way that it would be hard to untuck them. Only one I can find in my collection that looks like it would work well for this is https://www.daz3d.com/dforce-mi-two-piece-business-suit-for-genesis-8-and-81-males . It is designed to be tucked in, but since it is dforce, with a little work with dformers you can bring it outside of the pants, and the hem of the shirt is modeled in a way that still looks like a shirt (not cropped off).
Otherwise if you need something that is open further, the closest thing I can think of would be things like https://www.daz3d.com/dforce-wet-and-dry-boyfriend-shirt-dress-for-genesis-8-females which is designed for the female figures, but if you wanted something fully open (rather than just top buttons opened) this might be more flexible.
If you're not set on G8 (or are willing to use auto-fit or otherwise convert), there is a clothing set for G3 from Uzilite called M701 on gumroad. It's not in this store but if you google the name and gumroad you should find it. The shirt loads untucked, but the hem is short and straight all around like what you would see in a more casual shirt designed to be worn untucked (usually those have short sleeves). It does have a lot of morph options for opening at the collar though, so if that is important to what you need that may be a good option.
Hi thank you for your reply!
I tried purchasing the first one you mentioned - looks awesome exactly what I wanted... Save for the tucked in effect :( Tried to play with it but I couldn't achieve much - especially on the back of it. Too bad, it was nearly perfect...
I tried the second one too but when auto-fit on a male the shirt gets some weird effect under the pecs.
Do you know if the third you mentioned works good on G8 males? I could give it a shot at this point if so. I just want a long sleeves proper untucked in shirt T_T Thank you! :)
So I'm actually getting some armpit pokethrough with the generic auto-fit for the shirt, but I know I've solved that in the past (possibly with turning off surfaces). Honestly it's been a while since I've done much in Studio at all so my skill set is a little rusty, I am sure the fixes are easy once I take the time to remind myself about them.
Either way, this is mainly to show the hem. I also dialed in the most open morph for the shirt, it goes all the way to being completely buttoned up for ties, and opens a little to a lot, with separate morphs for left and right sides available for some variety.
Here's one for Genesis 3 Female with everything you asked for.
Here's one for Genesis with everything you asked for. If you add a smoothing modifer you can probably get any kinks out of it.
For the pectoral deformation, try using a Base Male body with Daz Original Genesis 8 Male Body Morphs to approximate the shape of your character. That way, you get the shape without the pec creases. If you have Nix 8, he's pretty smooth-chested, and his body may get you closer more quickly.
Thanks guys! I really appreciate your suggestions!
I tried with this one but again the deformation is still there. I tried to play around with modifiers etc but with little success... I'm afraid I am not nearly enough skilled.
I'm using a Scar 8 base figure. I don't think there is anything left to try? I also tried to play around with the first suggestion from the suit set but the tucked in situation really doesn't get better than this, so sad!
I'm not sure purchasing the GEN 3 one is gonna be any better, guess I could try and pray for good luck XD
My only hope is some kind soul to create some proper untucked in long sleeves shirt at this point :')
How open at the neck do you want? This suit: https://www.daz3d.com/q-suit-for-genesis-8-males has a plain button-up shirt. As does this: https://www.daz3d.com/hc-checkered-shirt-outfit-for-genesis-8-males and this: https://www.daz3d.com/dforce-casual-suit-outfit-for-genesis-8-males but none of these have a very open collar. If you are willing to branch out from this store, Renderosty has these: https://www.renderosity.com/mod/bcs/dz-g8m-gentlemen---unsuitz/145234/ and https://www.renderosity.com/rr/mod/bcs/dz-g8m-topz-3/144623/.
AH some more options I had no idea existed! Thank you! <3 I’m totally ok to purchase outside the official store, heck I’m down for custom made stuff too lol
I’d like something like this basically but with long sleeves. But eh I’m kinda desperate tbh, I’m ok to settle for anything that at least can open up a little bit at the collar :’)
- DZ G8M Gentlemen - UnSuitZ this is pretty close to what I was aiming for! Doesn’t look nearly as good as the short-sleeves ones you can find on the official store but this is def the closest match! Yay!
- About DZ G8M TopZ 3: are you sure it comes with the shirt? Because from pics and description this looks like a single piece? Can you use the shirt by itself?
- Q Suit for Genesis 8 Male looks tucked in?
- H&C Checkered Shirt Outfit for Genesis 8 Male as does this one plus there is an annoying chest pocked on it.
- dForce Casual Suit Outfit for Genesis 8 Male this one seems to be only possible compromise??
I'm not sure about DZ G8M Topz 3, since I don't own it. I just checked Q Suit and the shirt doesn't have any wrinkles around the waist, but the tails are pretty short. The Checkerd Shirt outfit has pretty short tails as well, so might not work for what you want. There is also this: https://www.sdebstore.com/collections/outfits/products/suitwell-pack-g8m which has a morph to open the collar. Here's a quicky test render of the three: Q Suit, Checkered Shirt, and Suit Well:
Edited to add: Here's Suit Well with the collar open.
Thanks everybody for the help :)
https://www.daz3d.com/men-s-shirt-for-genesis-3-female-s
You could try fitting that to G8M.
What AllenArt said. You CANNOT use Scar 8 or any other muscular figure without getting shrink wrap deformations. So, use the Daz Original Body Morphs (Bodybuilder, Fitness, or Bulk or a combination) and approximate the size of Scar 8 (DON'T use any details morphs), and you will have what you want.
Ideally, you would want him as smooth and featureless as this guys torso (also turn off the navel and nipples).
